Yep, the included instructions should tell you all about it.
Buying an S2 Coupe - Am I walking into a world of pain.
I'm not sure if you can just use different caps. But it looks like you need Bilstein 34-030868. These are the ones I have fitted to my coupe and I have a spare here to go on. It has a thread cap diameter of 55mm and a tube diameter of 45mm.
- 1 like
Originally posted by Colesy View PostI'm not sure if you can just use different caps. But it looks like you need Bilstein 34-030868. These are the ones I have fitted to my coupe and I have a spare here to go on. It has a thread cap diameter of 55mm and a tube diameter of 45mm.
Originally posted by B5NUT View Post
Yes, you need Billy's 34-030868 for the front. They will come with the tool to do up the top nut with the seal in it but not the rubber gaiter iirc. Don't forget to do the "Billy mod" and drill a small breather hole at the bottom of any strut you fit Billy monotubes to (there's a sticky on here about it, https://www.s2forum.com/forum/techni...ll#post2105783).
You can fit KYB 366008 to the rear if you want to save £200+ on using Billys on the rear. (They are narrower than the inside of the rear 55mm strut but come with a spacer to fit them)Last edited by johne; 9 November 2021, 23:44.
- 1 like
