Servotronic Steering Rack Service.
This is a sticky topic.
  • willg54
    • Jun 2009
    • 2055
    I can confirm the seal rack end seal still leaks. why the hell are Audi selling kits that leak the ******* :corey: ers. I am not impressed at all....
    Im going to try see i ZF can get me a single seal but i'm not holding out much hope...
    Anyone else who came across this problem, what did you do?
    1996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
    1994 Audi 80 - 2.0 8v (slow but reliable!)
    • willg54
      • Jun 2009
      • 2055
      Right, Autosuppliers in Kidderminster do their own kit for a whole sum of £20...if it doesnt work they'll happily refund and try to fix the problem they couldnt believe Audi are selling dodgy kits. Its worth a try....
      • LHD_Kid
        • May 2006
        • 3695
        #78
        What a nightmare, did you manage to pressure test before refitting to the car?
        I'm glad I waited to see how you got on... if the new suppliers stuff works, I think I'll give them a go...
        Good luck...
        Chris
          Will i think the kit from the dealer IS a ZF kit
          • AndyP
            • 6049
            Chucked it in the bin and bought a re-conditioned rack
            For the amount of work involved fitting it, I didn't want to take a chance with it leaking.
            • willg54
              • Jun 2009
              • 2055
              Its not the ZF, its their own kit. The ZF kit is £76!
              I may end up getting a reconditioned rack yet, but for £20 its worth a try. It cant be rocket science....
              I didnt pressure test it...just poured fluid into the open end of the housing and fluid dribbled out of the seal around the rack....no point putting it under pressure!
                yeah I wouldn't be surprised if it was a rebranded ZF kit since they made the OE rack
                maybe worth getting it rebuilt by a specialist at least they will have the facilites to properly test it before it gets shipped back to you... IIRC about £150-£200 is the going rate.
                If you are lucky you might even find a new old stock rack for that money
                • benntenn67
                  • Jun 2009
                  • 859
                  Steering Rack
                  Hi, I've not had a rack recon by this company, but I know of somebody who had calipers done with no probs -
                  Steering racks for cars, rally cars, light commercial vehicles, and everyday cars, either new or rebuilt, huge experience telephone for more information 0121 772 8000
                  Audi S2 Coupe 1995
                  VW Passat GL5 (hatch) 1986
                  Carrera Subway 8
                  • willg54
                    • Jun 2009
                    • 2055
                    Talk about embarrassing....I took another look at the rack today and the old rack end seal. I then realised, hiding under the plastic bush is an oring...the one I couldn't find a place for!
                    Quick rebuild and it appears to be holding fluid! I'm going to see if I can get it pressure tested somewhere this week.
                    Hopefully its all good!
                    edit
                    So people understand my ramblings...here's a pic to explain (not to the quality of other pics in this thead so i apologies!)
                    To make the rack end seal, seal A goes on the outside of the metal ring, C sits in the groove inside of the metal ring, then the bush B sits on the inside of C so you can't see oring C any more.
                    I had forgotten o-ring C basically....
                    Otherwise it's all the same as before. (note this a non-servotronic kit so a few seals are missing when compared to the picture on the first page)
                    • willg54
                      • Jun 2009
                      • 2055
                      still no leaks!
                      Moved the rack in and out alot and nothing is coming out, dry as a something very dry would be! pressure test will be the final test...think i might knock something up in the garage...
                      Anyone know what pressure the power steering system runs at?
                        d'oh! PAS system runs circa 140 bar
                        • willg54
                          • Jun 2009
                          • 2055
                          ok...ill take it to a pro haha
                          me...140bar...powersteering fluid...that would be one very dirty garage covered in red liquid...
                          • A80Avant
                            • 10873
                            • Country: Greece
                            #88
                            red liquid????
                            isnt it supposed to be green and only green???
                            • willg54
                              • Jun 2009
                              • 2055
                              red came out of it....im just using a bit spare to test it....
                                noooooooo! Audi PAS 101: Green Audi fluid ONLY, red ATF will **** the seals, that why it was leaking in the first place
                                Only use GOO2000 / GOO4000 from the dealer, and there is also a Febi aftermarket fluid that is the same spec... some say you can use Citroen hydraulic suspension fluid too but IIRc that more expensive than the real deal.
