Audi Coupe Quattro 2.3 20V - Czech Republic
  • Tom_
    • Oct 2007
    • 1301
    • Country: Czech Republic
    #481
    Honestly, dont know but I want to make my own manifold with some features and egt bungs as well. So if this doesnt clear thé bonnet, no problem, but I am curious too
    Odesláno z mého ASUS_X00QD pomocí Tapatalk
    • Tom_
      • Oct 2007
      • 1301
      #482
      Folks, does someone changed the fuel lines inside the fuel tank? Currently, I am thinking of changing stock fuel lines under the car with AN8 feed and AN6 return, but I think that the fuel lines inside the fuel tank are a "weak" spot. I am not sure how it looks inside the Coupe tank or if there is some pipe with fittings that are under the car. Only I can see is those fittings under the car.
      Detailed pictures of the pipes in tank will be highly appreciated
      • Jaswan
        • Apr 2011
        • 765
        #483
        I am using the stock aby tank/pipes/pump. Then running to a surge tank that can hold 2 pumps (will start off with one 525 LPH pump inside), that then runs AN-8 12.7mm line to the fuel rail.
        Jase.
        • Tom_
          • Oct 2007
          • 1301
          #484
          Where do you mount that surge tank? I ordered AN8 and AN6 for return.
          • Jaswan
            • Apr 2011
            • 765
            #485
            Mine is in the left side of the boot where the spare wheel once lived.
            Jase.
            • Jaswan
              • Apr 2011
              • 765
              #486
              But of course you could mount one under the car, possibly in the space of the factory pump/filter??
              • Tom_
                • Oct 2007
                • 1301
                #487
                Initially i will replace the stock fuel lines with an8 and will see how this work.
                • Tom_
                  • Oct 2007
                  • 1301
                  #488
                  An8 fuel feed Is in place. An6 return Will be put there this week. I already start the assembly thé engine bay. Yesterday I put a Phaeton dual booster but IT won't fit there because the plastic collar od Is bigger than od of the firewall. TDI pedal box is on thé place with a modified throttle pedal.
                  I 3D printed the Fuel Lines brackets And fit there perfectly.
                  Verkline engine mounts finally arrived. Have to make a washer to make the engine lower to clearance between the engine and the hood. Also, I have 5 egt sensors with stainless pipes. I want to go with 38mm of fór turbo manifold.
                  • Tom_
                    • Oct 2007
                    • 1301
                    #489
                    A refurbed steering rack is installed with new rods and joints. Finally, the pedal box is fitted and the throttle pedal is in good position. Dual stage vacuum booster is installed together with an aftermarket Brake bias valve for the rear brakes, but does someone know the correct routing of the brake lines from master cylinder should be routed and connected to the ABS and adjustable valve?
                    • Tom_
                      • Oct 2007
                      • 1301
                      #490
                      Egt sensors and bungs are placed . The wiring is also in the engine bay. I made ecu mount on the stock locations. Now i have to make a new tie rod rubber doors and put new fuel line holders in place
                      • Tom_
                        • Oct 2007
                        • 1301
                        #491
                        It's happening. The engine is mounted and looks fabulous. Another ton of work has to be done, but I am really happy that the engine is inside. Have to find the sweet spot for Volvo EPS, also the radiator is a little big bigger, so has to tilt a little. Hopefully, everything will fit.
                        This gallery has 1 photos.
                        • jbrentd
                          • Dec 2009
                          • 247
                          Looking good Tom!
                          2001 A4 Avant QMS - FXK04'd
                          1991 Audi CQ - Project
                          1996 A4 12v Quattro Manual - SOLD
                          • Tom_
                            • Oct 2007
                            • 1301
                            #493
                            Thanks, Brent. It looks like the forum is almost dead these days But some updates anyway.
                            1) I got a smaller turbine housing for my turbo, so now I am waiting for new turbo inlet /outlet flanges after I start making my custom turbo manifold, hopefully next week
                            2)I made a bracket for Volvo EPS
                            3) I get a SPAL rad fan as I don't have much space behind the rad, so I will fit that rad
                            Once these main jobs will be done, I will start making new engine harness.
                            • Lago Blue
                              • Jul 2009
                              • 843
                              Tom,
                              Re: "does someone know the correct routing of the brake lines...(re: brake bias valve)?" I have not done this but saw that Mance did this w/his famous 12v 90. He simply replaced the stock bias unit w/an adjustable Tilton unit in the original's location (i.e.: no change to the stock plumbing layout: M/C > ABS > BBV > Rr. brks.). But I've also read that Tilton doesn't recommend their units be used w/ABS. Mance's car (a B4) has slightly different ABS equipment than yours, however FWIW I'll try to find some photos to post. I read on other forum's that folks use OEM non-adjustable BBVs (because they are ABS tolerant?) from the same marque but various models to work w/ABS and get different but always less than w/no BBV; rear braking.
                              • Tom_
                                • Oct 2007
                                • 1301
                                #495
                                Hi mate, Thanks..I routed the brake lines like stock so that the new adjustable valve is adjusted before it enters into the ABS. It will need to decrease the pressure to almost zero and after that start adjusting.
