Some large button heads, and a flap disc in a grinder
Resurrection of my CQ20V
Well, a productive afternoon.
Tackled the rear main seal sump bolts, borescope in hand, behind hole number 1:
Behind hole number 2:
Suffice to say, that is definitely missing something in hole number 2. The mystery is solved, and predicted by newsh / Andy P .
Sorry for the quality, the borescope cost £7 and plus into an android phone/tablet, so you can imagine why it looks like this!
So, tackled this issue, turns out the cap heads that hold the crank sensors in place are only a few mm shorter, so used one of those, and replaced the sensor bolt with a regular hex head, fiddly to do up as you can't get a socket on it, but doable.
I removed the one that was in there, which was good and tight, and replaced both with a good amount of loctite for good measure.
Then onto the reason for the non-starts....
On the 7A, there really is no way to fabricate something to replace the pin, there is so little room (It is NOT like AAN/ABY square pins at all, see previous photos), basically you have the thickness of the pin, and the height of the pin to work with.
So, I cleaned the area up with a burr and sanding wheel, in a die grinder, with the earth lead connected to the front crank pulley, and the welder turned up to 11, I put a series of spot welds in a line, slowly building up without going too wide, to attempt to mimic the height and length of the pin. Once I'd exceeded it slightly, I pulled the die grinder out again and hand machined it back to the shape of the pin. This was important, as where the end of the pin stopped, there is NO room between it and the back of the engine. Similarly, if the pin was made too 'fat', it will hit the sensor -even with the stock pin, there were witness marks on the end of the sensor, so they are pretty close!
In the end, it looked like this:
It is smoother than the photo/reflections make it look, and definitely not proud of where the original pin was.
So, starter back on, refit cranks sensors, connect battery -'click' nothing..... turns out I had the solenoid wire on the wrong spade terminal, doh.
Switched it over, turned the key, and up she started! Phew... all good, thankfully, and hopefully never to happen again.Last edited by Bowie69; 19 May 2019, 22:40.
Tuesday evening, clutch started going soft when I left the house, got to where I was going with about half the travel left on the pedal.
The drive home left me with less than in inch of meaningful travel, and a pedal that was refusing to return, or pump up.
Got home and ordered a new master cylinder (you will see just a few posts above,I replaced the slave and pipe....), it arrived this afternoon, so fitted it this evening, took around an hour including bleeding and packing up.
Now, the ones with keen memories will recall I replaced the master back in 2017, obviously I am not best pleased about this, but in order to get one rapidly I have had to go a Pagid cylinder, the same as last time. Here's hoping I get more than two years out of it.
I disassembled the old one, the seal is looking really quite worn all the way round, and there is a groove in one side if it (not a cut, but a worn groove), so either a piece of rubbish got in there, or the machining on the cylinder was rubbish.
Amazing how the first one managed 16 years, the second only two....
Anyways, back on the road, after a day in the back up 1953 Morris Traveller
Hmm, think I know how I got caught out on that one, there is only one part number on OEMPC, listing from 8B-L-003682, mine is MA, sigh.
Pre-L:
http://www.oemepc.com/audi/part_sing.../272767/lang/e
Post-L:
Will have to look elsewhere
Mister auto? Got a pair of these on my car. Lemforder is as close to o.e as you can get without an audi logo on it somewhere.
https://rover.ebay.com/rover/0/0/0?m...2F311448001306
Ahh, yes they are. I didn't actually click on your links I'm afraid . As you have found out, for some reason the rears are a bit harder to come by and more money. No idea why as one end is the same as the fronts and the other end is a rubber bush which has to be cheaper than a ball joint?!
- 1 like
Bit of an update coming, probably multi-post....
About a year ago I hit a cat, this resulted in a nasty front bumper:
Grr, even lost the towing eye cover....
So, second hand bumper sourced, and with a small amount of filler, some rubbing down and some rattle can primer/basecoat/lacquer, I ended up with this:
Yes, it already has bugs smashed into it -I've told you this is a daily driven car, my only one, right?
Also threw some new indicators at it, as one got a chip out of it in said cat incident.
Yes, I am thinking of getting the rest of the paintwork fixed!
