Resurrection of my CQ20V
  • simons2
    • Mar 2010
    • 344
    Nice work , do you fancy doing my rear subframe ?
    • Bowie69
      • Nov 2013
      • 2675
      Thanks!
      Not really wanting to repeat, it seems a small thing, but was about 5 hours work yesterday, which is why a good one is so expensive, I guess....
      • simons2
        • Mar 2010
        • 344
        Yeah , I keep putting mine off but I know I have to tackle it sooner than later
        • Bowie69
          • Nov 2013
          • 2675
          Much easier to fix when there is actually something to weld to
          • Bowie69
            • Nov 2013
            • 2675
            For thos interested in saving themselves ~£40, Whiteline have 25% off their ARBs at the moment:
            Boost grip with performance car suspension parts from Whiteline. Rule every street & track with the best sway bars, coil springs and polyurethane bushes.
            • steve briance
              • Aug 2014
              • 1455
              Good spot re the ARB link. I've not spent a penny on my cq20v this year other than service costs, reckon i can justify a black Friday deal for the rear subframe!
              On the subject of rear subframes, have you considered galvanising? I had mine dipped and galvanised a few years back then I painted with black epoxy. I don't expect to do these again unlike my experience with powder coating.
              I don't know what paint you have lined up but it would have to be special to outperform a layer of zinc that becomes part of the metal itself...
              • John.
                • 2615
                +1 for galvanising .......and yes, had similar experience with powder coating.
                • Bowie69
                  • Nov 2013
                  • 2675
                  Yes, definitely not powder coating, too many horror stories and no real corrosion protection except the barrier.
                  Paint is likely to be bilt hamber electrox, which is 93% zinc in a paint, effectively doing the same as galvanising. Their site has details, following by a good epoxy top coat.
                  I would galvanise, but with lockdown and this wanting to be back on the road in a couple of weeks, there just won't be time.
                  • steve briance
                    • Aug 2014
                    • 1455
                    I like the electrox. As much bare metal prep as possible (maybe at least get it blast cleaned by someone?) you probably already know but the zinc galvanic protection doesn't really work unless it is in contact with bare metal.
                    The brackets I painted under the bonnet with electrox were dip in citric acid then brush cleaned. They still haven't got any corrosion now 4 years or so on and that's without top coat. Not as an extreme service environment as under the car but a good show non the less. ​​​​​​​
                    • Bowie69
                      • Nov 2013
                      • 2675
                      That's extremely encouraging, Steve, and yes, I am planning on getting it blasted, so the Electrox has maximum chance of working 'galvanically'
                      With a top coat of something, it should last even better
                      • steve briance
                        • Aug 2014
                        • 1455
                        I'm a fan of the Rustbuster products.
                        Used a epoxy 121 quite a bit now and it is great tough but a little flexible and covers so well with decent film thickness possible. It is just about spray able with a 1.8mm tip and some thinners and looks the biz.
                        I'm going to try some of their protect UVR epoxy next for an engine bay refresh...
                        It's got all the protection and toughness of 121 but is UV stabilised and glossy. The bonus for me at least is they do a colour match service so I can paint my engine bay in glossy indestructible body colour paint.
                        It's also available in black.
                          • Dec 2017
                          • 5992
                          I like Rustbusters and Bilt. I mix and match between the two. I've also recently used Fertan and very impressed. The good thing about Fertan is that you can power wash under the car and apply directly to the wet surface. Leave for two days and power wash again. Let dry and apply your chosen underseal (Rustbusters techshield), job done. Recently done the boys Polo and wife's Passat in this way.
                          • Bowie69
                            • Nov 2013
                            • 2675
                            So a bit of an update, I dropped off the subframe to the blasters on Friday, and was told a 3 week lead time(!). I suggested if they could get it done in a week, that would be fine, and left it with them for a chance to shine. Yesterday (Monday) they rang to say it was done(!). So all good, went and picked it up this afternoon. £25 well spent, nice and clean, ready for Electrox.
                            So.... some of you may have seen on the 7A clutch thread, I have the gearbox out -oh for a 2 or 4 post lift!
                            Clutch off, first look at the clutch cover, I don't think this is too bad, no?
                            and the flywheel, again, not terrible?
                            Do say what you think, I am not precious, if you think I have somehow rooted it, then just shout
                            There's no discernible lip, so I think it is probably good to go again.
                            Next, a bit of a look at the clutch friction material..... Not so good, I think:
                            So, on one side of the disc, the grooves are entirely worn away on the edge, which is a bit weird, there's one small finger-nail sized piece missing on the edge (not captured on the pics), and a couple of smears of moly grease (oops, put it down where I shouldn't have).
                            Reckon this is dead, essentially worn out in about 70K miles. Hmm.
                            So, one of the things I wanted to address was the massive oil leak coming out between the gearbox and engine. I say massive probably not that bad, but was enough to do this:
                            I knew it was a bit mucky in there from when I had the starter off, but wow.... that's a new level of skunge.
                            I forgot to take one of the gearbox, but the bellhousing is similarly splattered, in fact even more so than the back of the engine -I think I have leaks from both the input seal on the gearbox, AND the engine rear main seal. Good job I am swapping the gearbox then....
                            I had planned on the rear main seal replacement, so have a new Elring one in stock ready to go (and the one above is already removed).
                            Regular readers will remember I am replacing the steering rack as well, as I was convinced it was leaking. I am not so sure now, as, when peering around under the car, I could see the oil drips hanging off the rack rubber boot, and they were clearly yellow, and not green (plus, I am not losing pentison), and of course if it was engine oil, it would be quite brown. I am now hypothesising that the oil from the gearbox input 'seal' was running down the input shaft, release bearing, onto the clutch cover (it was wet with oil), and then being flicked out of the timing hole on the top of the bell housing, and thereby getting onto the rack end. Hard to test now, of course, but reckon it is plausible.
                            Other jobs done.... rack out (what a pain releasing from the column from inside!) and front subframe off, which will get a good clean(no real rust on it), and maybe some paint before being fitted up with the gearbox, including 930 engine mounts to replace the gearbox mounts.
                            ...and yes I know the heater hose take off is rough! Will be replaced when I get the engine out next year at some point.
                            • Bowie69
                              • Nov 2013
                              • 2675
                              Appreciate I have been a bit quiet on this recently, however, that does not mean there hasn't been a lot of work going on in the background..... things may have escalated a bit.
                              • Bowie69
                                • Nov 2013
                                • 2675
                                Rear subframe from blasting.... This then got a coat of Electrox, followed by Bilt Hamber epoxy primer in grey.
                                Oh, and the front subframe, and associated paraphernalia seemed to want to come off the car as well:
                                However, the blasters said it would be after Christmas for this one..... Couldn't wait for that, so out came the grinder with wire brush, and a it was given a good coat of Hydrate 80, then epoxy primer.
                                Then I spent a whole day, or more, with a grinder and a wire cup brush, and other methods of de-rusting stuff, essentially everything from the underside, struts, wishbones, anti roll bars, hub carriers, tie rods, driveshafts, hubs etc, before treating with hydrate 80:
                                Then..... epoxy primer:
                                Followed, on all of the bits, some 2K black paint:
                                So.... that explains the escalation, mostly. Other little bits are as I had the struts out now, I am replacing the dampers with Bilstein B6s all round, new rear strut mounts (fronts are fairly new and fine), and one new wheel bearing, which was silent but completely rooted.
                                No bushes in need of replacement, as they are all poly already!
                                Other small jobs.... replaced the engine rear main seal, which was somewhat different to the original, but presume it is OK!
                                Old:
                                New:
                                Bolted up fine, and looks to be sitting correctly, guess time will tell.
                                Also refitted flywheel.
                                Now I just have a massive pile of bits waiting to go on once I get a couple of deliveries with some more shiny parts!
