Ruby Red Audi S2 Avant
Wheel alignment
Yet another job which has been on the to-do list since... well really since i bought it, is to get it properly aligned. Hearing people say how nice their cars steer/corner i've always thought mine wasn't great in this respect.
I wanted to avoid the dealer as usual (my car has never and will never be worked on at a dealer). So i put my address into alignmycar.co.uk to find a place which can do the proper 4 wheel alignment. Hunter wheel alignment is meant to be one of the best.
Turns out Paul Bowers garage is on my doorstep and has the latest Hunter machine. I was very impressed with his service. I took it in and he discovered a few problems before he could do the alignment. Needed tie rod ends, ball joint, cv boot and a wishbone. Tonks sorted me some cast wishbones
Dropped it off on Friday knowing the Scotland Tour was the next day. What a transformation! Best quids i've spent on the car i'd say. Where as before even a white line on the road would unsettle the car now it stays controlled. I feel so much better throwing it into corners where as before i didn't really know what would happen
Still not sure i have the correct ball joint for cast wishbones?
1995 Audi S2 AvantComment
Also since i changed the Lambda sensor i'd say my mpg is better. Not by a massive amount but the last 2 tanks were 24mpg and 25mpg. This is mostly short drives though. I will post up what my next mpg figure is as it was the Scotland Tour weekend so any guesses to this figure before i fill up?!
You'll get better economy with all 4 wheels pointing in the right direction too!!.......but you might drive it harder through the corners as it's handling better so economy may dropAlso since i changed the Lambda sensor i'd say my mpg is better. Not by a massive amount but the last 2 tanks were 24mpg and 25mpg. This is mostly short drives though. I will post up what my next mpg figure is as it was the Scotland Tour weekend so any guesses to this figure before i fill up?!
It's a no brainer Anthony,get it done! ..........The love affair goes on Michael.
John.........Michael's gonna need all the entry and exit speed his new suspension parts can offer to keep up with a well sorted S6!
99 2.8 final edition CabrioletComment
Mike knows the score
.....that's why he's not spending money on his S6!Comment
Mike,what size tyres are you running?96 URS6 plus speck saloon
Mark...tyres are 225/40/18 if i remember right. Goodyear Eagle F1.
I also now run 15mm spacers all round instead of 20mm. Look wise i think 15mm on the back and 20mm front looks best, but i wanted to keep the same size on both axles.
28mpg for the Saturday leg of the recent Scotland tour. Considering the rate of knots we were travelling that's not too bad
Saying that i tootled back down the a9 from Inverness at a much slower rate.
Still not washed the car yet
Thanks Mike,i've got myself a set of these now
and just need to know the consensus on what size tyre people are running on these. I might be wrong but i think Macsprings running a 35 profile with his set on his S6?
I did notice in the pictures from last septembers epic that the rear wheels stuck out too much and didn't want to say but as you've mentioned it,reducing the rear will look perfect.
Thats what i love about these cars Mike,you can hurtle along at a rate of knots and yet overall the mps are still respectable and up there!
As to not washing the car yet
.....you naught boy!
255/35/18, on Mk1 S8 Avus rims which are 8" x 18 works for me.
8.5" or 9" might be better again, but it I like the S8 rims, and I don't want to have clearance issues. Besides the 255 tyre on the 8J rims means it is much 'harder' to scrape the rim on kerbs.
The wider tyre suits the bigger C4 body and also 255 is very hard to unstick.
I also found this with my S cars, and so I would also definitely recommend one changes the lambda probe with the correct Bosch one ( at 'about' £65.00stg ) you'll still find it is financially well worth while in a pretty short number of fills of the tank.
