Ok, so the write-up on the things I've done during the rebuild. All of the work was done by me alone or me & an assistant. All of the special machining work (measuring, pressure testing, etc.) was done by known and recommended professionals. I'll add pictures of the looks under the hood a bit later.
Engine:
*Block*
- Full rebuild of the AAN engine.
- Sourced bottom end from 1995 S6.
- Block measured and re-honed.
- Crankshaft measured and polished.
- ACL Race main bearings.
- King Racing rod bearings.
- FCP X-Beam 144x20mm rods.
- Stock pistons, cleaned.
- Mahle piston rings.
- Stock oil pump.
- Billet crank pulley.
- New crank pulley bolt.
- New gaskets all around.
*Head*
- Stock head, lightly skimmed & pressure tested.
- New AE intake & exhaust valves.
- New Metelli valve guides.
- New INA lifters.
- Valve seat & valve 45-degree backcuts.
- New cam pulley bolt.
*Misc*
- New flanges.
- New Mahle thermostat.
- New HEPU waterpump.
- Gates timing belt, INA tensioner roller.
- Gates aux belt.
- Mahle oil, air & fuel filter.
- Silicone water hoses.
- A/C compressor & radiator deleted.
- All possible sensors replaced except MAF, N75, N80 & injectors.
- New Corteco engine hydromounts.
- Proper right engine mount.
- Bought missing front snub mount.
- K24-7000 turbo from 1994 S2.
- Stainless steel injector inserts.
- Billet throttle cam.
- Wagner RS2 EVO exhaust manifold.
- Copper nuts on exhaust side.
- New exhaust system gaskets.
- Replaced fuel rail.
- New injector o-rings.
- Modified breather system: valves deleted, straight line from the block distributor to intake transfer pipe through a baffled catch can. 20mm diameter.
- Repair kits used on both clutch cylinders.
Suspension:
- 28mm front ARB with poly bushes from Albert.
Brakes:
- New front ABS sensors.
Steering:
- Replaced steering rack, servotronic works now.
- Brand new TRW single-contour PAS pump.
Fluids:
- Motul 8100 X-Cess 5w-40 engine oil.
- Motul Gear 300 75w-90 gearbox & diff.
- Motul green hydraulic fluid for PAS system.
- G13 coolant.
- Ferodo DOT4 brake fluid.
That's about it. I'll add if I missed something.
Engine:
*Block*
- Stock oil pump.
*Head*
- New INA lifters.
*Misc*
- New flanges.
- Gates aux belt.
Suspension:
Brakes:
Steering:
Fluids:
- G13 coolant.
