S2 avant, emerald green.
    • 4754
    Originally posted by anthonys2
    Good parking there John!! Is it my eyes or does the back light on your S2 look is if its hanging off
    I had to do a double take
      • 4754
      Originally posted by geneandbolly
      Bess ponders, .. .. 5 cars he's definitely having a midlife crisis! What with the mostachoed funny business and the chest chains nonsense i bet the neighbours are thinking
      Bess is thinking
      • John.
        • 2615
        It's the reflection of the Coupe that's making it look weird.
        • John.
          • 2615
          Originally posted by Vorsprung durch Technik
          Bess is thinking
          All Bess thinks about is food, and maybe about the odd tennis ball.........that is all!
          • John.
            • 2615
            Some pics from yesterday, had a wee drive up to Perthshire to meet up with Mike. A good blether had and naturally a few photos taken.
            • John.
              • 2615
              Jobs done so far,
              Best attempt at making the paintwork look better.
              Top hose and MFTS replaced.
              Cooling system flushed and comma G30 antifreeze put in.
              PS pump X plug replaced.
              Tightend/adjusted boot catches.
              Unseized the rear wiper arm hinge.
              Repaired the leaking rear screen wash bottle.
              Jobs still on the list,
              Fit new bulbs to dash switches.
              Sort seats so they don't move when you tip it hard into corners!
              Clean door checks.
              Scrub interior.
              Sort bonnet, N/S catch missing from bonnet?
              Check brakes, underside etc.
              Replace creeking strut top mounts.
              • geneandbolly
                • Sep 2013
                • 1356
                that's not what she text me the other day . . .
                1997 Audi S6 - The Purple Helmet!
                • geneandbolly
                  • Sep 2013
                  • 1356
                  Luvvit, Luvvit........LUVVITTTTT-AHH!!
                    #39
                    Consider an oem S2 bonnet grille with black surround. Matches oem S2 bumper grilles.
                      #40
                      Jobs done so far,
                      MFTS replaced.
                      Did you notice any change when you installed the new MFTS, was it oem or Behr ?
                      How did you tighten the new power steering x plug ?
                      Presumably one of the two little white plastic clips are missing from one of the rear 'legs' of the seats, (or less likely the 'rubber' insert at the front, if the tipping is from side to side, rather than front to back.).
                      • John.
                        • 2615
                        Hopefully the grill situation is in hand.
                        MFTS was Behr I think, only replaced it as I'd ordered one thinking the original was kapoot.........only difference was psychological !
                        X-plug I tightened with a screwdriver then a wee chap with a chisel.......
                        Feels like the rear of the seat is loose.......will report back.
                          #42
                          Yeah, btdt. Consider ordering a new light brown electrical connector plug for the MFTS from the Dealer.
                          It ensures the connection is good and allows you to check the condition of the pins in the old connector when you break apart the old connector before fitting the pins to the new connector.
                          Make sure to photograph the layout of the pins in the old existing connector plug before carefully break it apart a bit at a time.
                          • John.
                            • 2615
                            I know you can get a repair kit for the plug/wiring but it's not required....the plug and wiring connectors are in surprisingly good condition, so they were given a squirt of ACF50 and plugged back in!
                            • anthonys2
                              • 3512
                              Looking excellent John
                              • Ian_C
                                • Oct 2007
                                • 1008
                                Looks superb
                                B5 B6 B7 B9
