Where did you get the subframe bolts from ? I’m after a set
My Ocianic Blue Ur restoration
VW heritage on ebay.
https://www.ebay.co.uk/itm/Hexagonal...edirect=mobileNothelle S2 Avant
Urs6 plus project goneComment
I suppose you could use shouldered M10 10.9 grade bolts no issue. I used very thick stainless washers with them. Got those a couple of years back on a forum group buy. It's amazing what those 4 little m10 bolts hold up somehow.Nothelle S2 Avant
Not much. It was totally overhauled about ten years ago by another forum member and not done many miles since. Just cambelt, water pump etc and I need to pull the clutch and check it's ok. I've already fitted new mounts.Nothelle S2 Avant
Water pump looks not to bad. It's dated 2010 which is about when the engine was overhauled. The replacement is identical.
Everything stripped and given a good clean.
The cover got cleaned and treated.
Then some zinc.
Then satin black
The clutch plate is good and has plenty of life. It's dated 2011.
The cover is also good.
The flywheel is original and stamped 1985. It's in good order. They don't make them like this anymore.
So after a clean up it all went back together nicely.
Sent from my iPhone using TapatalkNothelle S2 Avant
I needed a better tool for holding the top pulley secure when torqued up and removal. I got thinking.
Fits perfectly and made from a trolley jack bar and some scrap metal that I had knocking about.
And I made this new heat shield ages ago.
Good to see the proper bushes being used, you'll be guaranteed they'll seat right compared to poly
B&Q do tubing by the way
Nice work.
Thanks John.
Having used poly and oe, I do prefer the oe. Much easier to get the subframe aligned as well.
My nearest B&Q is 20 miles away
I didn't know some Audi parts were made in England!
It's coming back together
Oil pump has been replaced at some point.
Wonder whats happend to that can gear? Looks like its been rubbing against something and has had a wallop right by the England stamp? As always Dave, top job!Comment
It's been rubbing against the back cover. The cover was slightly bent so I fixed that. The marks are probably where someone used something inappropriate to hold it when removing before.Nothelle S2 Avant
The gearbox and engine are friends re united.
I was waiting for this pulley but it turned up like this.
Not very round.
Then I had to mow the blinking grass.
While it was nice and sunny I got a few more bits cleaned and painted.
admire your work!!!
