My Kingfisher Blue S2 aby update and revival
Chris, I found John's air filter-box photos, please ignore my previous photo request, sorry to trouble you.
John, thanks for pointing those photos out sir and yes, both those boxes have lid-exit V-stacks leading to the MAF housings, very interesting to me.Comment
Right guys!! I need your help!! I have bought the Fluidamper from the states, but apparantly I need to zero balance my engine before I fit this. Is this really needed?
I have a Nurburgring trip in 2 weeks today. I still have to fill with oil , arrange a map, 4wd alighnment, underseal it and replace 2 washers under car gearbox drain plugs.
Is it easy to strip engine and take these things out and get it to a specialist in time?
What do you reckon? and can anyone suggest any specialists please? ... ahh man this has screwed me :/
yes they are interchangeable,aslong as they dont have balancing marks.
Attached FilesComment
Ah balls! Mine has 3 holes, what does this mean?. I should drill into a new unit i purchase?
Urs6 plus project goneComment
Fit the fluid damper and see what happens. If it doesn't vibrate excessively, happy days
But whatever you do, don't let your mechanic touch it with that impact gun in your pic
Ah man, I am getting conflicting advice here. I have just phoned a machine / balancing shop J and E. Their suggestion is to purchase a second hand unit and fit for the ring and my intention was to run this for the next year / 2 years. They said it would be a lower chance of failure.
My original they said would fail. The new fluidamper he said would need balancing to engine and be very far out he said.
That is his advice. He also said other things can fail also, ie when engines are pushed. Though at least the other damper will be closer to specification.
(I remembered also on the old damper I felt a vibration at a certain rpm that I didn't like, and I would try to quickly pass through it when driving or avoid that part on acceleration through using gears etc.. - perhaps this was the point that the engine doesnt usually like? - I think it was low rpm before the boost. Could that be the part of the engine that usually gets balanced / or harmonised? just a thought on that one....
How about this option:
I purchase 2nd hand one... fit fluid.. if fluid vibrates, I fit the 2nd hand one?
Or just 2nd hand one -- even though the balancing is different.
(on looking at mine I have 3 drill holes on mine - so not loads --- the 2nd hand one has 1 drill hole, but at opposite end of the damper compared to mine)
What do you guys think? also what expoeriences do you guys have? are you machine specialists? I need a trust source / answer from a reputable source.
Ok bingo!! Thank you so very much everyone!! I have just purchased the second hand one.
I phoned MRC Tuning, J and E Engineering (on balancing etc) and with you many great members!
I will install this for the next few years, and hope for the best. I heard also that my s2 will have a dual mass flywheel, being an ABY. So this also would take strain away from this part. (more food for thought).
Fingers crossed I dont get catastrophic failure.
in 1 year / 2 years I will then look at stripping engine out / rebuild in situ and modification upgrade in situ, is the plan.
Thank you all so very much for your help! wish me luck! then I can get it on the road and do meetups etc with you guys again too.
