struikie - Audi 80 B4 quattro project
  • struikie
    • May 2019
    • 314
    Got the fuel filter holder I designed today. 3D printed in ASA. Put in place and
    made the hose from the filter to the rail. It feels good putting things back on!
    Also had the fuel pump tool 3D printed in PETG.
    JW
    | project | 1993 Audi 80 VR6 turbo quattro |
    | daily | 2018 BMW G31 530d | 345bhp 770Nm |
    • struikie
      • May 2019
      • 314
      Put the front suspension back on today.
      The aftermarket fender liners (van wezel) fit like crap. Anybody have experience
      with a better fitting alternative?
      JW
      • struikie
        • May 2019
        • 314
        The fender liners are thermoplastic, so a heat gun does wonders ;-)
        The bolts for the caliper to bracket weren't available in a galvanized version, so I got a DIY kit.
        While I was at it, also did the bolts for the brake pads.
        Put the discs, calipers and pads back on.
        Was a little bit confused by the fact that the brake hose was very long. When
        I first fitted these brakes I had ordered black lines. That one was too short.
        Ordered new (longer) ones, but got clear lines.
        In the end I think I swapped the brake lines that go around the damper from
        left to right. So now I could fit the black lines I originally ordered.
        JW
        • struikie
          • May 2019
          • 314
          Designed and had some parts 3D printed in TPU rubber.
          Caps for the slots in the rear suspension mounts. Through the slot
          I can access the damper adjustment without the need to take it al apart.
          Ring on the front suspension cups.
          Covers for the front strut mounts.
          Fuel line rubbers for feed and return line.
          I am ditching the evap.
          JW
          • ert
            • Aug 2007
            • 16
            As far as I know 10,9 and 12,9 bolts aren't supposed to be galvanized.
            • struikie
              • May 2019
              • 314
              Good point because of hydrogen brittleness. I have enough spares left.
              You can plate them, but have to bake them after. Even then it isn't guaranteed to fix the brittleness.
              I'll have a think about this.
              JW
              • struikie
                • May 2019
                • 314
                Treated the rear wheel wells with the Dinitrol 447.
                Next up is cleaning the gas tank and fitting the Walbro pump.
                JW
                • struikie
                  • May 2019
                  • 314
                  Wrestled the pump out of the tank. Broke the 3d printed tool but managed to
                  still use it by drilling two holes, sticking a 1/4" extension through it and using a
                  27mm spanner from the top driven by a stick through the ring end...
                  Got the remaining fuel out of the tank with a Pela vacuum pump. Not much
                  crap to be seen in the tank.
                  Cleaned the outside a bit. Need to finish that later.
                  Put the Walbro pump in the basket. Need to get a suitable hose clamp and thinking of buying a new
                  connector instead of reusing the original.
                  What do we think about the cracks around the outlet connection?
                  It's two different cracks from the front and the back.
                  JW
                    • Dec 2017
                    • 5983
                    The cracks are common. If its not leaking, don't worry too much. Support the banjo with mole grips of plumbers wrench when tightening and removing the nut.
                    • struikie
                      • May 2019
                      • 314
                      One clean tank.
                      Crimped on a new connector for the pump.
                      I suspect this connection is sitting too high. Ordered a banjo style fitting.
                      JW
                      • struikie
                        • May 2019
                        • 314
                        Walbro 450HP in place.
                        I think the return lines inside the tank got orientated differently over the years.
                        When the cover is lined up correctly, the notches line up with the gaps in
                        the return connector. No possibility of rotating one side 90° so fixed the
                        connector in place with a tiewrap.
                        Removed the evap system. Put a checkvalve (allowing air out) in place.
                        Made the fuel lines.
                        3/8 cunifer into AN6 PTFE.
                        Put the front wheel well covers in place.
                        Put the rear bumper back on.
                        Cleaned the exhaust system.
                        JW
                        • struikie
                          • May 2019
                          • 314
                          Happy that I managed to snag a correct under body tray.
                          Wrestled the fuel tank in place. Had to massage the new stainless tank straps a bit here and there.
                          Finished the fuel system.
                          Tomorrow I'll try and fit the subframe.
                          JW
                          • Jaswan
                            • Apr 2011
                            • 760
                            #253
                            Well done!
                            Looks a really tidy job you have done
                            • struikie
                              • May 2019
                              • 314
                              Some progress today.
                              JW
                              • struikie
                                • May 2019
                                • 314
                                Put the diff back on.
                                New brake line.
                                Put some thicker wires to the fuel pump in place. Used the original wires
                                to switch a 30A relay. Will need to tidy things with some cloth tape.
                                The Walbro can draw quite some current. This would have fried the original
                                1.5mm2 wires for sure...
                                Ordered new black Goodridge brake lines to the S4 calipers.
                                Couldn't resist checking out how the new wheels would look.
                                I think I made a good choice!
                                JW
