struikie - Audi 80 B4 quattro project
  • struikie
    • May 2019
    • 314
    Found it. I'll have a look.
    https://www.nonpaints.com/nl/u-pol-p...spuitbus-400ml
    Also found a company that does 'sticky button' repairs. They can in-house laser the illuminated logo's.
    Welcome to the world of Rinovo Autospa (Hengelo), where we unlock your car's full visual potential and take the entire process off your hands.
    Bij veel Italiaanse sportwagens treedt na verloop van tijd een herkenbaar en frustrerend probleem op: plakkerige knoppen in het interieur, beter bekend als sticky buttons.
    Think I'll send them some pictures to get a quote.
    JW
    | project | 1993 Audi 80 VR6 turbo quattro |
    | daily | 2018 BMW G31 530d | 345bhp 770Nm |
    • niall4313
      • Oct 2011
      • 186
      The sun visors are the only part I couldn't get to work. The paint didn't take well to them. Are there any other cars with the same shape black visor that could be used instead?
        • Dec 2017
        • 5983
        Same here. The paint gets sticky in the hot sun and sticks to the headliner slightly so i leave them slightly down. 80 Cabriolet are black but slightly smaller if you can live with that?
        • niall4313
          • Oct 2011
          • 186
          The roof liner is shaped to accomodate the visor, and I'm not sure how it would look. I did think of chopping out the liner and re-forming it with fiberglass.
          • struikie
            • May 2019
            • 314
            I keep on buying extra pieces to the puzzle ;-)
            Walbro 450 HP pump + install kit
            034 motorsport adapter
            What type of bigger fuel lines are people running under the car?
            Power goal with the VR6 is about 500bhp.
            JW
            • Tom_
              • Oct 2007
              • 1301
              • Country: Czech Republic
              #186
              An8 feed and AN6 return...but the bottleneck is the fuel tank feeding hole. So good to cut the fuel tank and weld a new an fittings...check my topic to see that
              Audi Coupe Quattro 2.3 20V
              • struikie
                • May 2019
                • 314
                Thanks I'll have a look!
                JW
                • struikie
                  • May 2019
                  • 314
                  Finally started working on the Audi!
                  Straight away I ran into a problem. The KW V3 damper interferes with the Porsche caliper
                  I placed in front of the hub.
                  Swapped left and right dampers: damper hits the cv joint
                  Turned inward: damper would be inside the car
                  Spent an evening in 3D cad and concluded that there is no other place
                  to put the calipers to clear the reservoir.
                  So I have to revert back to a single caliper.
                  Looking at the A4/Q5 330x22 disc (same offset as the S4 B7 300mm disc).
                  Epytec has a simple adapter for the B5 RS4 calipers and carriers for a 300mm disc.
                  Adding 15mm in the bracket would make it fit the 330mm rotor.
                  So now looking for RS4 B5 calipers and carriers. Made an offer on kleinanzeigen to a guy
                  selling a set including discs. Those discs are expensive!! The 330x22 discs are much cheaper.
                  I realize that the offset of the B5 hub is different to the B4 one so need to have the parts in hand
                  to be able to design a bracket myself.
                  JW
                  • struikie
                    • May 2019
                    • 314
                    These will need addressing.
                    All the shields are toast. Any chance I will be able to source them all?
                    JW
                    • struikie
                      • May 2019
                      • 314
                      Got some 'better' parts from Germany.
                      The cover for the gas tank behind the rear right wheel is on it's way from Audi Tradition,
                      together with one lower rear control arm of which I ordered only one previously...
                      JW
                      • rxl
                        • 1913
                        the heatshield on the fuel tank will not fit and will need modifications.
                        • struikie
                          • May 2019
                          • 314
                          Yep, I saw that being mentioned here somewhere.
                          Anyone have some tips and tricks for removing the gas tank?
                          JW
                          • rxl
                            • 1913
                            would be intresting if you can remove the tank without removing the rear subframe.
                            • struikie
                              • May 2019
                              • 314
                              It's already off hahaha
                              Doing a suspension overhaul and fixing rust on the rear half of the car.
                              JW
                              • struikie
                                • May 2019
                                • 314
                                What products are you guys recommending for (spot) repair of the under body coating in the places rust has formed?
                                JW
