My starter motor (solenoid) decided to slowly die. Got a used one
and swapped it in today.
Engine has been lumpy for a while. Can't find the cause.
Swapped injectors (refurbished)
Checked plugs - all look fine
New leads (I had broken one)
New coilpack
New cam sensor
New crank sensor (also because of the new seal)
Vacuum lines hold vacuum
Set FPR at 4bar with no vacuum attached
Checked compression - all get up to 12 bar
Pulled the vacuum line off the FPR. When blocking this
off I can hear a leak. With the line open I cannot hear
that same hiss. I'll pull the intake next weekend and see what
I will find.
JW
New coilpack
New cam sensor
I will find.
JW
I'm actually in the same position, spent a lot of cash on my 'competition' as well, thinking of selling it but the price must be right, or just keep using it and just enjoy it. Hope you can enjoy yours for a while now without issues!
