Yet another 3B engine rebuild
  • #31
    I was over at Steve H's today and he was telling me thats what Dialynx do. Also that hillclimb car uses flattened pistons. Im not sure mate..... I have no experience with this. I cant afford to do JE pistons like you, so do I leave the pistons stock or shall I **** around with them??
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • #32
      If thats what Dialynx do, and I know that hillclimb car is very highpower, so it must be OK then .
      Mark.
      Mark - Modded
      • #33
        Wahey, thats what is gonna happen then. I love being a guinea pig
        Audi UR Quattro
        • #34
          In stead of machining the pistons flat why not shim the head with the parts from a second gasket? Will do the same thing but cheaper, and also reversable if it turns out to hurt squish too much.
          • #35
            Doesnt last very long. Thought about that. Gaskets tend to blow out
            Audi UR Quattro
            • #36
              I cant see why it would blow any easier than a normal steel layered rs2 type gasket. They are already made of many layers, so one more will make no diference to reliability. I have used this way to lower CR on VW audi diesls that have much highter Compression preasures and have had NO problems.
              • #37
                If the skimmed pistons are good enough for Dialynx and a 600hp hillclimb car, then im sure it will be fine for mine!
                Audi UR Quattro
                • #38
                  and that one, they are not in order, but can you see the ****ed one?
                  Audi UR Quattro
                  • #39
                    and the new ones
                    Audi UR Quattro
                    • #40
                      Nice bent rod. New ones look ££££. When's it all gonna be back together ? Is Castle Combe gonna be too soon ?
                      Now RS2'less
                      '99 VW Passat VR5 Sport
                      • #41
                        Sweet Tom - No wonder your car was running like a bag of nails.
                        Welcome to the Arrow Club - lets see who's the first to bend an Arrow Rod !
                        • #42
                          Hope its not me
                          Mark - Modded
                          • #43
                            Did any arrow users get a free sticker? I didnt, and for a grand i would have expected some!!! Im gonna get some made using the logo on the box. Doug/Mark do you want one for the car/engine bay?
                            Car wont be ready for CC Im too far advanced for rushing it now. Most of theengine is at the machine shop now.
                            I have opted to machine the pistoms down, this should give a CR of about 8.7/8.8:1. Been speaking to Grant at AET about turbos today, Im goona go for the same one as he was using about 1.5 years ago. K26/27 #8 hotside with a custom coldside for increased durability and good EGT's. The housing alone is 360+vat, but they will use my existing shaft 'section'. Total cost is about 680+VAT. Im told that this will be good for 500+bhp. That should be the last turbo I buy.
                            I had a real good chat with him today. He listed all the options out and basically said, how much power do you want? When I said that the current blower was at its limits he suggested this one. Only problem being lag is gonna be a bit worse, full boost at about 3800rpm, instead of at 3200rpm. Ah well.
                            Audi UR Quattro
                            • #44
                              What a sight I hate seeing the car like this. Hopefully should be up and running in 2 weeks time. Hopefully will get all the bits back from the machine shop next week.
                              Audi UR Quattro
                              • #45
                                So far the mods are as follows.........
                                Modified head
                                7A cams
                                RS2 Exhaust manifold
                                RS2 injectors
                                RS2 intercooler
                                Skimmed pistons (8.8:1 ish)
                                Arrow rods
                                Lightened flywheel
                                Helix clutch
                                K26/27 #8 with modified coldside housing
                                This should produce around 400~450 bhp without any problems.
                                We will see
                                Audi UR Quattro
