And here are my old pistons, that have been 'altered'
Yet another 3B engine rebuild
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nm -
And the re-conned turbo.....
Attached Filessigpic
Audi UR Quattro
Audi B5 RS4 645ps 911nmComment
And the modded pistons on the new rodsAttached Filessigpic
Audi UR Quattro
GR8 pics of the before and after pistons. Be interesting to follow you enigne build and see what kind of CR you will get. It will also be interesting to see how your motor will run with the "squish" area removed from the pistons.Originally posted by audimanAnd here are my old pistons, that have been 'altered'Comment
It will either run like a bag of rubbish or fine? We will see in the next few weeks. Cant wait to get to it running againsigpic
Audi UR Quattro
They look good Tom.Originally posted by audimanIt will either run like a bag of rubbish or fine? We will see in the next few weeks. Cant wait to get to it running again
I personally don't think they will run bad. Eventual drawback, if OEM piston was really supposed to use squish effect in any manner, would be not being able to run as much boost as the std design (with same CR) before knock occurs. But this might be a very small difference.
If we really would point out any possible difference, there also is the reduction in height between crown and first ring, which, in very heavy working conditions, might let it work at slightly higher temperatures.
All this is of course purely academical. Differences, as said, might be very negligeble, while saving some significant money for high performance aftermarket pistons.
MarcoComment
I drew that!!!!sigpic
Audi UR Quattro
Tom - getting excited for you now... looking like a mighty engine spec that should be more than capable of exceeding a reliable 400bhp and I'd guess 600Nm. I'd say your 3B manifold and original MAF will be the limiting factor now, but it should be fun chewing through clutches, gearboxes, somerset hedgerows and small animals with this setup in the meantime
Were you a good boy - weighing everything and buretting the chambers and bores to calculate CR properly (so that we have hard facts for the future) or are you just going on blind faith that everything is OK ?
Start thinking about how you are going to run this baby in. If it was me I would disconnect the WGFV and reduce boost to dull levels of 0.6bar so that you can give it some stick in order to bed in the new rings properly. PS - don't firkin forget to measure the ring gaps on assembly... and double check the thread cleanliness and torque settings on all the critical bolts. Sorry for preaching to the choir, but when all the parts arrive its very tempting to just build it all and throw it back in the engine bay. Do one or more dry builds first and check the crank runs nicely. You know the score !
PaulPaul Nugent
Tom - got any side profile pics - I'd like to know the wall thickness.Originally posted by audimanHere are some pictures for you lot
Std piston(has been cut in half hence the line)
PaulPaul Nugent
I havent buretted them yet. But all the pistons weigh the same now
I will remove the cable tie that is holding that cut piston together and take a piccy.
Audi UR Quattro
This arrived today, but it has a dent in the top of it
Not sure what is gonna happen about it yet.
Took 2 days to come from Hong Kong. Quicker than UK post
Audi UR Quattro
this is a close up of the damage. Luckily Dougs is OK
Audi UR Quattro
