Hey Alex, not sure if you are aware that Bosch ISVs fail 'open' a bit, so that if they do fail, your engine will still idle. To actually close an ISV it is quite common you need to run it at 25% duty cycle.
Forgive me if teaching a granny...
Also interested in what you think has made the difference in driveline shunt? I still get some though it is better, have new OE engine, OEM gearbox, OEM diff mounts (and a big poly one in the back) and a new snub rubber, oh and poly subframe bushes.
