My 3B Coupe project - Total rebuild
This is a sticky topic.
    cool good info cheers andy - great project BTW
      Originally posted by AndyP
      Yes, I forgot about that. I took the turbo back to Grant, who built it in the first place. I asked him what difference the bigger 0.7A/R coldside I had would make over a std size and he said not a lot. Plus I want to try and retain the RS2 airbox and I couldn't get a MAF to turbo hose with a 4" end so I got him to swap the coldside back to std.
      Or more likely you were scared by my actions to getting it to fit with the RS2 box.
      Best solution for all I reckon going back to the original coldside.
      Are you going to use washers to space down the passenger side engine mount or is the mock fitting on your car o.k for height because your not using a reverse manifold?
      • AndyP
        • 6049
        Only time will tell on this one, I'm hoping that with a std inlet manifold it's not going to be much of a problem.
        • AndyP
          • 6049
          Took the winter wheels off today and fitted these
          Can anybody photoshop them so the centres are the same colour as the bodywork?
          • Big Lee M
            • 2571
            I bet I know where you got them from. Nice wheels fella.
            Just some finishing touches to do now
            • AndyP
              • 6049
              Go on then!!
              • AndyP
                • 6049
                Made some progress on the exhaust. This is the Jetex back box
                I cut the std flange off and stepped it up to 3" to mach the rest of the system.
                This is the middle silencer and pipe work
                It's all just tacked at the moment but I had it all on the car this afternoon and the alignment is near perfect
                I picked up the parts I need this week to make a back purge set up on the welder, so I'll have a practice and then get this lot welded.
                • AndersS2
                  • Sep 2005
                  • 1364
                  • Home: Norway
                  #143
                  Great project Andy!
                  Can't belive I've not seen this before now.
                  Are you thinking of lowering it?
                  Anders - S2 Avant Clubsport - 8pots or die!
                  • Acidburn
                    • 13459
                    Keep up the good work andy
                    • AndyP
                      • 6049
                      Originally posted by AndersS2
                      Great project Andy!
                      I fitted my lowered springs a few weeks ago, they were std springs that I had lowered by 15mm. I checked them before and after and they were down by 15mm, but when I put them on the car only the front went down. The back is still at 660mm ride height, which I've been told is std
                      Only difference front to back is 034 street density top mount front and Audi blues rear.
                      • bikerjim
                        • Feb 2008
                        • 1028
                        Sounds daft and im dont mean to sound patronising but has the car been driven or not, i fitted a lowing spring kit to my car and took it a couple of days to settle in.
                        • AndyP
                          • 6049
                          Another thing I've just remembered, when I fitted the springs I fitted new hubs and struts off a later car ( ABY? ) with the larger M14 strut to hub bolts.
                          Are these in any other way different to early 3B struts?
                          • Acidburn
                            • 13459
                            Check the diameter of the shock tubes as I found two different sizes on my s2 when I had it.
                            • AndyP
                              • 6049
                              Well, there is no going back now, the engine is going in this weekend.
                              I've dropped it off the stand and fitted the flywheel and clutch
                              Started to strip parts off the old engine
                              I sense it could be a long weekend
                                Deja Vu?
                                Can't wait for this one to be done been far too long
                                Looking good mate
