My 3B Coupe project - Total rebuild
This is a sticky topic.
  • Good luck andy, keep us updated, looking forward to hearing this done, you bringing it to any combe shows?
    • Get up there and give the man a hand Jamo
      EDIT: where did you buy your exhaust pipe from Andy? Struggling to find the flared end parts to use the compression ring things
      • Nice one Andy, should be good for the next Leeds meet?
        Just some finishing touches to do now
        • Originally posted by Error404 View Post
          I struggled with those too, I ended up getting Exhausts UK to flare the ends and I had the rings made. Let me know if you need any, I can get more done.
          • Cool thanks Andy, good to know
            Are you putting the box in along with the engine? did you ever sort out the reverse switch wiring issue for the 01E convertion?
            • Gearbox has been in for ages. The reverse light wiring is easy, just get a std Audi 2 pin female conector and extend the wires so they reach from the passenger side to the drivers side of the box.
              • Panthero Coupé quattro 20vt
                  I'm sure Andy wants things to go smoothly
                  • good luck this days and take the bull ¡¡¡ i want to see this engine working¡¡
                    • Well, it's out, lots and lots of cleaning to do now before putting the new one back in.
                      • nice times andy.. I hoped i had the chance to clean my engine bay, maybe reinforce it with a bit of more heat resistant sheets etc.
                        good luck!
                        • Marina Clean is your friend
                          • Dont forget to check the engine height vs bonnet clearance before you do up the engine mounts
                            Looking good!
                            • It's in!!!
                              All wnt quite smoothly, I gave the engine bay a good clean and painted the chassis legs with POR15. Fitted a re-con ABY steering arack and a new damper whilst I has access. Still a grade 1 pain the the *** though, anybody who tries to do this with the engine in is seriousley deranged
                              Looks like the cam pulley is hitting the bonnet, not by much though. I think the removal of the trim on the bonnet and spacing the engine mounts down by 5mm with fix it, but thats a job for tomorrow.
                              • Looks Great!
                                Looking forward to seeing it running!
                                Nice garage floor btw. And i feel for you with the rack, pita!!
                                91 S2 coupé - RIP
                                98 S8 - Luxury barge
