My 3B Coupe project - Total rebuild
This is a sticky topic.
  • Acidburn
    • 13459
    Good luck andy, keep us updated, looking forward to hearing this done, you bringing it to any combe shows?
      Get up there and give the man a hand Jamo
      EDIT: where did you buy your exhaust pipe from Andy? Struggling to find the flared end parts to use the compression ring things
      • Big Lee M
        • 2571
        Nice one Andy, should be good for the next Leeds meet?
        Just some finishing touches to do now
        • AndyP
          • 6049
          I struggled with those too, I ended up getting Exhausts UK to flare the ends and I had the rings made. Let me know if you need any, I can get more done.
            Cool thanks Andy, good to know
            Are you putting the box in along with the engine? did you ever sort out the reverse switch wiring issue for the 01E convertion?
            • AndyP
              • 6049
              Gearbox has been in for ages. The reverse light wiring is easy, just get a std Audi 2 pin female conector and extend the wires so they reach from the passenger side to the drivers side of the box.
                  I'm sure Andy wants things to go smoothly
                  • Rocco
                    • Aug 2007
                    • 6393
                    • Country: Spain
                    #159
                    good luck this days and take the bull ¡¡¡ i want to see this engine working¡¡
                    • AndyP
                      • 6049
                      Well, it's out, lots and lots of cleaning to do now before putting the new one back in.
                      • A80Avant
                        • 10873
                        • Country: Greece
                        #161
                        nice times andy.. I hoped i had the chance to clean my engine bay, maybe reinforce it with a bit of more heat resistant sheets etc.
                        good luck!
                          Marina Clean is your friend
                            Dont forget to check the engine height vs bonnet clearance before you do up the engine mounts
                            Looking good!
                            • AndyP
                              • 6049
                              It's in!!!
                              All wnt quite smoothly, I gave the engine bay a good clean and painted the chassis legs with POR15. Fitted a re-con ABY steering arack and a new damper whilst I has access. Still a grade 1 pain the the *** though, anybody who tries to do this with the engine in is seriousley deranged
                              Looks like the cam pulley is hitting the bonnet, not by much though. I think the removal of the trim on the bonnet and spacing the engine mounts down by 5mm with fix it, but thats a job for tomorrow.
                              • s2_bo
                                • Oct 2005
                                • 6067
                                #165
                                Looks Great!
                                Looking forward to seeing it running!
                                Nice garage floor btw. And i feel for you with the rack, pita!!
                                91 S2 coupé - RIP
                                98 S8 - Luxury barge
