My 3B Coupe project - Total rebuild
This is a sticky topic.
    Ah so you finally told the world Andy!
    Where did you get hold of the torque plate and bolts mate for machining?
    • AndyP
      • 6049
      I had to make the torque plate as I couldn't find anybody with one to suit the TDi's larger head studs. I spoke to Aelred about borrowing his, but when he checked the holes for the studs they were too small.
      The bolts for holding it in place are just std M12 cap heads ( 12.9's ) got them from our nut & bolt supplier at work.
        I had planned to use Aelreds torque plate but if it don't fit thats out the window. I must admit I hadn't asked him to check the stud hole size
        • breitling
          • Dec 2005
          • 491
          • Country: Norway
          Nice looking car.. Beutyful colour.
          Keep us posted
          Audi RS4+Long sportquattro
          www.hansenmotorsport.no
          • AndyP
            • 6049
            Got the block back from the machine shop this week so I got the ARP studs and crank fitted so I could check the main bearing sizes
            Turned like butter when torqued up
            Got the first piston fitted
            JE Pistons and Sten Parner rods. Now the scary part, I have to grind the bottom of the bores to clear the rods. This is an example I found on the web
            • AndyP
              • 6049
              More goodies
              JE custom piston
              155mm Sten Parner rod
              New oil pump
              034 adjustable cam sprocket
              Bosch Green top injectors
              Crank bearings
              Innovate Motorsport AFR gauge
                Lovely
                • AndyP
                  • 6049
                  Originally posted by Jamo
                  Why does the block need clearing? I thought this only applied to the 220mm block??
                  Nice bits btw you'll have yours running before me
                  Yes, me too, but when I put the first piston & rod in it would not turn. On doing some more research on the net I found that the block does require grinding. Marco had to do his, it's just not mentioned in the thread, this is yours I'm told
                  The picture I posted above came from here
                  Explore a world of precision-engineered brushless motors for all your RC and hobby needs. Each product crafted by expert engineers to deliver top-tier
                  The guy had a thread running on here but it's not been updated for ages
                  Andy
                  • Mark Halligan
                    • 2001
                    Great project Good luck
                    Mark - Modded
                      Andy
                      Cool, I'll confirm that in pics when I strip the block
                      Learn something new everyday.
                      What CR did you go for on your JE pistons and what was the psiton volume?
                      • Billman
                        • 4129
                        #26
                        How significant is to use a Torque plate?
                        Go Holset or Go RS4
                        • AndyP
                          • 6049
                          I would always use a torque plate if you can, but the machine shop who did my rebore said it was not necessary as the block was so strong anyway.
                          They would ony use a torque plate when boring an engine with large bores, on a Yank V8 for instance, they said most german blocks, especially ones from late 80's early nineties are super strong from the factory. After these dates accountants started getting involved, and to a certain extent they lost the 'built like tanks' build quality.
                          • Flat on my back
                            • Jan 2007
                            • 2449
                            Oi...
                            Get some tape over those main bearing oil holes...
                            Hope you've got an air line to blow them out with.
                            Carlos.
                            • AndyP
                              • 6049
                              Thats not my block, just an example of what I've got to do. Don't worry, when I do mine it will be well masked off.
                              • Flat on my back
                                • Jan 2007
                                • 2449
                                phew...
                                big sigh of relief...
                                Carlos.
