Project: RS2 ABY
    Sounds ****ing awesome
    • Sonic
      • Jul 2006
      • 5514
      #1952
      It has some real presence now, before it was very subtle and only at full chat would turn heads. Now it trundles through the local villages with a throaty rumble and a very real feeling of power hidden underneath which turns heads.
      S2Forum.com Administrator
      • andy10v
        • 5996
        Sounds very nice, very meaty.
        Sold ABY-stock
          Got some rasp on that thing now Sonic proper job
          • Sonic
            • Jul 2006
            • 5514
            #1955
            The guys repairing the road couldn't get enough of it
            • prj
              • Mar 2010
              • 6308
              WMI can be any number of things:
              1) Failsafe messed with, thus always going into failsafe mode (were the gauge trimmers adjusted?)
              2) No actual flow due to pump not turning on or blocked pickup.
              3) Leak
              I've never ever had a single problem with an Aquamist kit I've fitted. First thing to do is to remove the jets, aim them somewhere and put it in test mode to see if it sprays or not.
              • quattrostyle
                • Oct 2006
                • 6229
                Originally posted by Sonic
                Back, for now.
                I can't view it
                  Andy you need to mirror the video image so it looks like LHD, and load it up under a different user ID
                  • TimE-J
                    • Jul 2009
                    • 1292
                    Originally posted by quattrostyle
                    I can't view it
                    Same...
                    96 S2 aby Coupe. Rebuild Project
                    96 mk3 golf tdi daily.
                    • montyrs2
                      • May 2008
                      • 522
                      Can't watch video either
                      • Sonic
                        • Jul 2006
                        • 5514
                        #1961
                        So the WMI problem was restricted flow caused by the check valve.
                        The o-ring in the valve has swelled which is blocking the flow, likely as a result of mixing the meth mix in an old race fuel can... Rubber and hydrocarbons don't mix
                        The valve is being sent back to Aquamist to get the o-ring changed and I'll drain the entire system and flush with water before sourcing some new, hopefully uncontaminated, methanol.
                          http://www.chemiphase.co.uk/methanol...-virgin-grade/
                          • Sonic
                            • Jul 2006
                            • 5514
                            #1963
                            Yeah, just trying to work out how much methanol is a safe amount to store in the garage.
                            The 200L is tempting because it's such good value after you factor in postage on a 20L, but sounds rather dangerous!
                            Methanol group-buy anyone?
                            • AndyP
                              • 6049
                              I wouldn't buy 200ltrs, I bought a 25ltr drum from Trinity Chemicals and it's lasted well over 8000miles.
                              • Sonic
                                • Jul 2006
                                • 5514
                                #1965
                                50L of 50/50 water/meth mix, so 25L of meth would probably last about 2 days on track from what I understand
                                200L would last me a decent time for sure, it's great value to buy it in bulk, but I'm not sure I fancy storing it all so if anyone wanted some...
