In which case even more surprising then given they're completely OEM.
Project: RS2 ABY
So moral is check the main AND head arp for valve crush.
here is the 034 custom ARP with warning about main stud http://www.034motorsport.com/engine-...-i5-p-343.html
no head stud warning http://www.034motorsport.com/engine-...lve-p-158.html
Honestly never heard of the head bolts causing this before must have missed a80avants issue with it in the past.Comment
The head studs cannot have caused this, look at where they are in relation to the one way valve. The studs screw into the block about 50mm max, the one way valve must be at least 100mm away.
1976 RD250E / 350LC cafe racerComment
Hmmm I think I need to get mine checked now.... I'm only seeing 1bar on a warm/hot idle and after a Castle Coombe thrash it was down to 0.8bar. Still >4bar at 2,000rpm though so I'm not concerned...
Glad to see you got to the bottom of this Andy, I assume Rich had to pull the rad etc out to get to it rather than haul the engine back out?AUDI - saving Dad's from minivans since 1994
Just measured my 3B block and the one way valve is 185mm from the deck surface, it's the mains bolts/studs that are crushing the valve.sigpic
yes, i must correct, its the main bolts that did this to mine.
i was lucky that my original setup had this crushed but still made 100K kms without issues. I guess the mechanic realised there was something there that shouldnt overtighten at the time!!
good news Andy!Comment
Just been out with Sonic for a quick Bedding In run. Car is so smooth and positively reeks of potential
Haynes Manual:As described in Chapter 7...
Translation:That'll teach you not to read through before you start, now you are looking at scarey photos of the inside of a gearbox.Comment
