UrS4 2.2T Avant project
  • quattro-nick
    • Sep 2012
    • 1746
    • Country: Belgium
    #1681
    Originally posted by Thuppu
    What can cause so high injector duty? Bad engine blowby? Or is it high? I have no experience with these kind of things...
    I also had this problem in the past so I have set my fuel pressure higher and problem was solved (i'm using a adjustable fuel pressure regulator)
    here is a picture where i measure the fuel pressure on AAN fuel rail
    TWINCHARGED power,zero lag
    AEM W/M injection
    • Thuppu
      • 4115
      Well, I don't have any electronic fuel pressure monitoring, only an mechanical gauge on the FPR to check the base pressure. And I use 4bar base pressure. But I could fit a second mechanical gauge outside the window to see how the pressure acts at boost.
      • Tille
        • Feb 2014
        • 41
        From my experience:
        S2 2.5l 908PS E85 1980ccm Injectors 100% DC
        S2 2.2l 780ps E85 1980ccm Injektors 90% DC
        So its ok i think
        Audi Coupe Typ89 10V Turbo - VEMS - Billet K26 - Deka 630 - E85 - 3" Exhaust
        • Thuppu
          • 4115
          Ok, thanks!
          • mushasho!
            • Apr 2007
            • 163
            Where'd you get that banjo bolt?
            I had to make my own bolt with 1/8 NPT thread...
            _Rubí_
            • quattro-nick
              • Sep 2012
              • 1746
              • Country: Belgium
              #1686
              my father had a some used banjo bolts so therefore i do not know exactly where it comes from
              AEM W/M injection
              • Thuppu
                • 4115
                Back to old good times... or not. I did take apart the old block with forged internals that have been lying in the garage for a couple of years. This engine had the big oil burning issue, and in the end it started to keep some noise. This was found in cyl no 2.
                • V6quattro
                  • Sep 2008
                  • 949
                  1360kg/600Whp Avant 0-200km/h 9sec
                  • K Simmonds
                    • Dec 2007
                    • 7627
                    Wow, that came from an engine that was still running!??! It would certainly explain the noise.
                    1990 B3 2.0 80 quattro.
                    1992 C4 2.8 Avant quattro
                    1994 MTM RS2.
                    1998 B5 TDI quattro Sport.
                    2000 B5 TQS.
                    • Dima ABY
                      • Sep 2013
                      • 183
                      • Home: Ukraine Current: Spain
                      #1690
                      Wow!!!
                      Looks like this engine has not worked a lot.Pistons are shining.
                      Sorry for that.
                      • AndyP
                        • 6049
                        Dam, that sure took a pounding!!
                        • prj
                          • Mar 2010
                          • 6308
                          I wonder WTF happened.
                          Regarding hot running on AAN it is always Cyl 3 that is the hottest, followed by Cyl 4 and only then comes Cyl 2.
                          • igor136
                            • Jun 2014
                            • 363
                            • Country: Croatia
                            #1693
                            Did you have measure clearance between the pin and the rod bearing before?
                            1-2-4-5-3
                            • Thuppu
                              • 4115
                              The main issue was that the engine burned oil... really much oil... I mean a ton of it... I mean worse than a TFSI. I think that lead to e85 pre-ignition and high cylinder pessure, caused burnt spark plug electrodes, burnt valves, propably lifted head becase of this and in the end hammered the piston pin. This is just my theory.
                              • prj
                                • Mar 2010
                                • 6308
                                Preignition usually just silently melts the piston, rather than lift head, destroy pin etc.
                                Also, in that case it would be cyl 3 or cyl 4, they are much hotter than cyl 2.
                                Something else is amiss.
