Originally posted by macspring
View Post
UrS4 2.2T Avant project
Soo, here is an small update on the power figures, 624hp/737Nm.
The supercharger will propably eat some of the power, but you can't get anything for free. The owner told that on a Bosch dyno the result will be something like 700hp/800Nm... Would be nice to try to see if it's true. Anyhow, the car has never before been so fast as now. In fact it's quite sick.
First the power seemd to stuck at 560hp. But then we tried stiffer springs in the WG and directly gained 50hp. Would propably have been giving a few hp more, but started to get proplems with the fueling. The fuel was burning hot, and maybe a pump started to die or the filters was glogged, it suddenly started to go lean in the upper end. Feeled that the one pump was hotter than the other. Couldn't hold my hand on the pumps.
Started to be problems with the charge temps also. 70+ celsius degrees seemd too much. When spraying water on the IC the temps hold at ~60C. Feeled also that the small IC after the supercharger restricted some as the turbo spoolup was worse than before.Last edited by Thuppu; 14 July 2015, 19:27.
BTW, Maxxecu worked like charm. No problems there. Really nice ECU.
Did this 86mm one-way valve the day before, and it seemd to work better than the smaller one. Now the silicone hose on the turbo intake didn't try to collapse, so not soo much vacuum in the intake pipe when the turbo spools up.
Hope this will help the fuel temps a bit. Had these bits from before but didn't have the time to fit them.
Yes a little bit. Not much if compared to how it was before with the smaller valve. Also on supercharger boost it's like an balloon.
Sure it would be better, but who will make me a same size and offset pulley with a clutch that holds when turning on and off at 4000-5000rpm?
