UrS4 2.2T Avant project
  • Henkjan
    • 1705
    the oil pump is a gear type pump, thus flow is fixed (at a given speed). with the flow fixed, the pressure at the parts that need to be lubricated is also fixed (by the resistance to flow). if changing something on the relief valve results in higher pressure, then there is a restriction downstream and thus a problem somewhere.
    • prj
      • Mar 2010
      • 6308
      Originally posted by Thuppu
      Maybe the spring is progressive and always open? Little at idle and a lot on higher rpm's...
      I don't think so.
      • Thuppu
        • 4115
        Next thursday is dyno time. Fun to see how much it gives on springboost, and nice to get someting you can compare to later.
        Any bets of the powerlevel? http://koti.mbnet.fi/pro-ht/Audi_URS...4_test_run.mp4
        No dyno today. The roller movment hydraulics got broke just when I drove the car on the dyno, so couldn't adjust the rollers to fit the wheelbase. New try next wednesday.
        • Laaf
          • Oct 2010
          • 275
          Where do you take it to get it dynoed?
          • Thuppu
            • 4115
            To the local technical college laboratorium. They have a calibrated 4wd dyno. Have been there twice before.
              #876
              http://rosten-performance.no/produkt...ljepumpe-5cyl/ Ok, great. Few years back, on our finnish forum, when I ask about shimming the oil pump no one knew nothing about it. But seeems that this kind of information is secret on our forum.
              If you're in touch with Rosten, can you encourage them to hurry up with their English version of their website ?
              I would have thought there're missing out on a lot of english speaking I5 customers potential business.
              Thanks.
                #877
                Haven't recently read all of this thread, can you remind us why the first rebuilt engine was using such a big amount of oil ?
                Thanks.
                • Thuppu
                  • 4115
                  Havn't measured the block yet. Must be that the cylinders are out of round. The low tension rings don't seat in that case.
                  • Wrath
                    • Jan 2011
                    • 779
                    Thanks.
                    That´s a Norwegian site (Norway) and Thuppu is from Finland
                    1995 Audi S6 - AAN (~350hp)
                    2008 BMW 530xd (235hp)
                    • Thuppu
                      • 4115
                      Fun dyno day today. Everything worked out nicely. Performance turned out as quite nice numbers, if you think that it was only 1,7bar springboost and the timings was for gasoline. I'll guess there is some potentional left there... There are two plots, first with 7A cams in stock position and second with the cams 2 degrees advanced.
                      612hp/617Nm (533whp)
                      • V6quattro
                        • Sep 2008
                        • 949
                        Nice! How much boost and what fuel?
                        1360kg/600Whp Avant 0-200km/h 9sec
                        • Thuppu
                          • 4115
                          Boost is only controlled by springload, it creeps up to max. 1,7 bar. Fuel is E85. Dmitri did leave a "supersafe" map because the head lifted when he mapped the car. I think we where beyond 2,2 bar (propably much more because my vacuum hose to the ECU was leaking very badly, and it's the reason why we maxed out the injectors).
                          • Rocco
                            • Aug 2007
                            • 6393
                            • Country: Spain
                            #883
                            Very good Tomas!
                            And this with the stock engine with Aron rods?
                            98 fuel timing map using E85?
                            Where should be the limit with full 100% mapping completed?
                            700?
                            • AndyP
                              • 6049
                              Great results for your 'Ghetto winter' engine!!
                              What's the turbo??
                              • Thuppu
                                • 4115
                                Originally posted by Rocco
                                Very good Tomas!
                                700?
                                Yes, that's right. I have heard they have exeed 700hp with this turbo and E85 so it could be possible. Somehow the engine felt so easy at this level on the dyno, at least in the car. It didn't sound like it's struggling or anything.
                                What's the turbo??
                                Yea, first I build a engine with no compromises, it didn't work out. Then I throw in some random used parts and everything is good.
                                Holset HX40 Super with #16 size hot side.
