UrS4 2.2T Avant project
  • prj
    • Mar 2010
    • 6308
    Sigh, time to go to Seinäjoki again...
    If it did 600+ hp on this map, I wonder what it will do with correct boost.
    Thomas, do you still remember how much faster it was with more timing and 2.2 bar?
    And I guess now there is no longer the problem with the engine using as much oil as using e85?
    • Thuppu
      • 4115
      Originally posted by Henkjan
      time for the E85 then, could bring you to #1
      btw: do I see a diesel with 479 horses on #8
      I'm using E85 but the map isn't ready yet. And yes, that MB is a superdiesel, have seen the car closely. It have a nice little 4" exhaust. Powersmoke needs a big pipe to get out.
      Originally posted by Prosac
      hi thuppu
      congratulations to your income. have you tried with a DriftBox 100-200kmh times? I have a c4 s6 avant and similar hardware. 2.6bar-2bar (aral ultimate 102 octane) out of the top because the egt is too hot. also with super hx 40 16cm ², vems, mech. cylinder head. 100-200kmh best time 7.4sek.
      DriftBox power 408kw at wheels.
      this winter I will rebuild on E85, then cruise over 2bar from 7000 u/min
      Thanks. I don't have any performance box, but you can calculate some from this vid I posted earlier. Maybe the car is something like 1700-1750kg(?) including me. Quite slow shifts... http://koti.mbnet.fi/pro-ht/Audi_URS...4_test_run.mp4
      • Thuppu
        • 4115
        Yes, I think so also. Would love to get a casoline map also + plus some other goodies. Quite a lot faster, it feelt so lame after you dropped it to springboost and easy timings. Lame 600hp.
        I havn't need to refill oil anymore, not ones. And the sparkplugs are shiny bright too. So, I'll guess it works now like it should be.
        Edit. Dmitri, one thing we could do now already is to add some cold start fuel enrichment. -20 degrees and it needs to start maybe ten times before the engine stays on running.. It always dies right after the start. Few seconds after the engine has started you can drive the car no problem, so no need to add fuel to warmup map.
        • prj
          • Mar 2010
          • 6308
          Ok, will do this.
          Did not get a chance to test the E85 cold start in -20C weather yet
          • Thuppu
            • 4115
            Great, it must already be quite close to right amount of fuel. It fires up right away when cranked but stalls in a second or two. Hope I remember how to write the chip.
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              #906
              When will you meet guys?
              • Thuppu
                • 4115
                • Rocco
                  • Aug 2007
                  • 6393
                  • Country: Spain
                  #908
                  What brakes do you have ( front and rear) to stop this tank with 600hp and soon 700?
                  • Thuppu
                    • 4115
                    You wan't sell me some?
                    B5 HP2 30x321mm in front and stock with uprated 22x310mm discs in rear.
                    • prj
                      • Mar 2010
                      • 6308
                      Good video, can see how the breather is pushing out of the catch can.
                      I am really really happy that it is working out for you after all this trouble.
                      • Prosac
                        • 108
                        hi thuppu
                        this is a video from me. my C4 weighs 1775kg without me already. (+80 Kg with me).
                        Your car runs great as it seems.
                        408kw @ wheel
                        • Rocco
                          • Aug 2007
                          • 6393
                          • Country: Spain
                          #912
                          hi thuppu
                          tell us more please
                          1775Kg without people inside?
                          or maybe you should create your own thread where all can go and post sh.it
                          • Prosac
                            • 108
                            hi. the weight is the empty weight. the audi s6 c4 avant is really heavy. but small, light and fast can almost everyone
                            I make no separate thread for me.
                            I'm interested thuppu's conversion much, as mine is similar.
                            408kw @ wheel
                            • Thuppu
                              • 4115
                              hi thuppu
                              - vid -
                              That is really fast! How much power and what turbo? The UrS4 is lighter, my is also without aircon. Maybe 100-200kg lighter..?
                              BTW, just realised when I look't at my dyno vid, the engine sitts quite solid in the bay, zero movement, so no wonder there is some resonances inside the car.
                              Got a cheap china 50mm BOV. Don't know if it's any good, but we see soon.
                              For future I would also need a boost gauge with vacuum and pressure to 3bar readings. This kind 80mm would be nice.
                              Fitted just like in this vid, in the middle of the dashboard. Of course the driving is like that also. http://www.youtube.com/watch?v=ao0ACOOFATE
                              • Prosac
                                • 108
                                Hi. I have the same bov. Let the weaker spring in it, the strong spring is too hard. the valve opens too late and the turbo pumps against the throttle.
                                I have also the holset hx40 super in there. I can't get the power. I know only the performance box values. 408kw were at wheel. I dunno if that's true...
                                408kw @ wheel
