Here you go Thomas, I think this one will be perfect, unless you want black?
Don't know how much the pinns can take, they are 22mm though, and lightened. This kit was made back in 05 and have been laying around in a shelf since that. Got them really cheap. I want ot modify the top, mill off a bit to make higher CR, so I was in contact to Ross and they told I could safely take off 3,7mm of the piston top land. With 155mm rods I would take less, but either way that mean I have to mill off the block also. Have to measure the block before anything, if it's sligly more than 236mm(like 236,6mm or something) then I may go with 159mm rods. That's why I asked this: http://www.s2forum.com/forum/showthread.php?t=68839
On WOT it burnt less, propably because boost forced rings tighter to the walls. On baby drive the consumption was quite enormous. Yes, there was usually some smoke at stertup but when the engine heated up there was not visible smoke on idle. But when driving in normal traffic usually you could see a blue cloud behind you.
