UrS4 2.2T Avant project
  • Thuppu
    • 4115
    You look at it. It looks like a simpple black pipe.
    • Billman
      • 4129
      #767
      Show us data and give us prices! How does it work?
      Go Holset or Go RS4
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        #768
        Yes indeed!
        And also tell us the IAT before and after!
        • Thuppu
          • 4115
          Have to log a little bit more. But it seems to be really efective, it drops the intake air to almost sub zero even if the outside temp is about 20C degrees.
          • prj
            • Mar 2010
            • 6308
            LMAO you guys are so owned.
            • Thuppu
              • 4115
              Dmitri, you don't have to belive the results, but this seems to be really really promising. For real.
              Edit. I will put some log data soon.
              • Rocco
                • Aug 2007
                • 6393
                • Country: Spain
                #772
                Could be used with meth?
                Less lag, more power,no compromise
                • Thuppu
                  • 4115
                  Tomas, it just look like a simpple pipe outside, but inside is full of small pipes. It can add some lag, but this 3" version should be good for ~900hp. I'm just not sure I have fully understand the function of this, but the pipes inside is some kind of ceramic material and have a nano tech coating that absorbs the heat from the air. It have been developed in Sweden and should be for sale at Dahlback Racing soon.
                  • diesel des
                    • 3896
                    #774
                    Is it just for your mot...
                    Sent from my GT-N7105 using Tapatalk 2
                    • Thuppu
                      • 4115
                      Des, you are absolutly right. Hahaahah! Sorry guys.
                      • A80Avant
                        • Sep 2005
                        • 10873
                        • Country: Greece
                        #776
                        Yes indeed. I thought for a while the black hose has tiny holes but yeah. That was a good one. Summer sun takes the mind off!
                        • diesel des
                          • 3896
                          #777
                          • Billman
                            • 4129
                            #778
                            I remember reading that you took the IC Off for mot....
                            That was in front of me while reading the forum:
                            Go Holset or Go RS4
                            • A80Avant
                              • Sep 2005
                              • 10873
                              • Country: Greece
                              #779
                              Nice tan Billman
                              • Billman
                                • 4129
                                #780
                                Yes....but not mine! I am whiter than white! Use only 50 SPF!
                                Go Holset or Go RS4
