UrS4 2.2T Avant project
  • Thuppu
    • 4115
    -18 degrees here today. Heater plugged for one hour and started nicely.
    Edit. The car has never idled so well it does now. It idles perfect when cold and perfect when warm. Nice. Waiting forward to get some power also.
    • kotnelson
      • Oct 2008
      • 48
      • Country: Thailand
      #707
      Greeting, just read only 40% of you topic.
      2 thumbs up for all things has done. I go through out your topic....
      Many great input and helpful, I am preparing my engine to do an upgrade with GT2870 or similar.
      Tks,
      Spec 118.1mm VS current 117.8mm
      corrosion weld up
      Tranny
      Clean out
      New clutch
      Old clutch
      • kotnelson
        • Oct 2008
        • 48
        • Country: Thailand
        #708
        - Expect to start up the engine this Sat with stock Motronic 2.3.2 ..... run with E20 for a tank.
        - Fill up with E85 and install RS2 replica injector and will try to start up to see overall result with adjustable FPR.
        - Change to VEMS, fine tune with E85 and LPG
        - End 1st stage project
        Next project in mid 2013
        - GT2870 or similar
        - FMIC 9"x18"x2.5"
        - Injector 0280150558 440@3bars
        - DP
        - Front brake upgrade
        - LPG upgrade (300 KW reducer, injectors)
        - Expect approx 380 bhp on E85 and 350 bhp on lpg
        • Thuppu
          • 4115
          Nice updates kotnelson, and great plans. That head musta have been welded a lot, the waterholes look quite funny.
          You don't need any upgrades for your chassis, like solid front subframe bushings?
          • kotnelson
            • Oct 2008
            • 48
            • Country: Thailand
            #710
            I have done all the F+R sus including new front rotor and street track pads.
            Convert to vacuum assist brake as well.
            • kotnelson
              • Oct 2008
              • 48
              • Country: Thailand
              #711
              Log type EM with stock K24-7000
              New Rotor and Pads
              Friction 0.55, up to 800c good for street or track day.
              • kotnelson
                • Oct 2008
                • 48
                • Country: Thailand
                #712
                New Tire....Assym II 235/45/17 with BBS RS702 8*17 ET35
                I have done all the basic need, and preparing for the bigger turbo.
                - Ignition system replaced with D585 and spark wire from BMW E28
                moved D585 behind firewall to avoid heat
                - Nippon Denso IK24 plug with 0.4-0.5mm gap
                - Replace brake vacuum from A6 with 15/16" master cylinder (Stock is 1")
                - All breath hose and 1way valve
                - Hose for cooling system
                - New Radiator
                - Sub-frame
                - New suspension F+R (Ball joint, bushing, rubber etc)
                - Fuel submersible hose replace with Nitrile hose to handle Ethanol, Methanol, Nitro
                - FP from Denso, for 2JZ-GTE 340 HP engine (not 100% sure if flow enough for E85)
                - FPR adjustable 2-7 Bars
                - Monroe Relex Shcok Ab....plan for custom made from Hotbits Monotube subtank
                • Thuppu
                  • 4115
                  Sounds great. Seems that you have so much mods on your car that it would be best that you do a own "Project Thread" of your car. Especially the brake assist change seems interesting...
                  • kotnelson
                    • Oct 2008
                    • 48
                    • Country: Thailand
                    #714
                    Reason I post in your topic, I see many things that is great and I can apply to use in the future.
                    So I better share some of my mod as well.
                    I am lazy to open new treat and post. Actually I have open in my local area which in THAI.
                    Mainly on mod and VEMS tune. Here it is http://www.audiclubthailand.com/boar...?topic=27799.0
                    Tks for many great stuff I will keep following your treat.
                    Kot
                    PS. I can post up on the brake booster swap if you'd like.
                    • Billman
                      • 4129
                      #715
                      Make another thread about your brake booster! That way it is easier to be found when someone is searching about it.
                      Go Holset or Go RS4
                      • my2000apb
                        • Jul 2010
                        • 637
                        Yes, a T3 twinscroll housing, but not a twinscroll manifold because there is 5 runners.
                        is that a 16cm housing>?
                        BEAST '90 CQ 24v VRT / O1E / v8 rear, HOLSET SUPER 40 http://www.theprojectpad.com/viewtop...1&t=193#p37887
                        DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.theprojectpad.com/viewtop...1&t=201#p38264
                        • Thuppu
                          • 4115
                          Yes it is.
                          • my2000apb
                            • Jul 2010
                            • 637
                            t3 or t4 hard to tell in pics
                            • Thuppu
                              • 4115
                              T3...
                              • Prosac
                                • 108
                                Looks like my 16cm Holset Housing
                                408kw @ wheel
