UrS4 2.2T Avant project
  • When you plan remap ECU ?
    • Soon... must really start to plan this out. Have to negotiate with Dmitri... Have also to run in the engine before remapping.
      • Very nice work friend!
        How many horse power can you run with that engine and turbo? Also with my aquamist hfs3...700?
        • Don't know about the engine. According to CP, their piston pins should hold for 175-200hp per cyl. I think the head is the restricting part on this engine, have no clue what can be possible hp with it..? The turbo is good for 600-680hp, so I would be dissapointed if we get under 600hp.
          • Dmitri said that MAF RS4, more than 600+ can not handle!
            • Originally posted by Thuppu View Post
              If the car is tuned properly, good piston pins will not fail even with 200hp per cyl.
              600hp+ with hx40 super should not be a problem if everything is working.
              • Originally posted by Melber View Post
                Yeah, it will max out, but can still map a little bit of it to last cell.
                It was not too bad on a GT35R and 600hp. I think it will be pretty similar here.
                • Are we talking about crank- or whp? http://www.s2forum.com/forum/showthr...t=49825&page=2
                    I'm talking about crank hp. 600whp would be around 750 at crank and that would really be pushing the envelope with Super.
                    • 600 crank yes...
                      • Originally posted by kenax View Post
                        Yes, that is obvious. Was thinking of the RS4 MAF max out thing... In the link ~700 from crank with GT35R.
                        • It maxes out between 500 and 600hp, depending on how much air you need to reach those hp.
                          But as I said - that's OK. The boost control is still closed loop, so it's safe.
                          • nice one Thomas....I bet you are happy to get running it in....and then mapping it.....
                            It will be worth the wait when you get back out on the track....
                            this year perhaps?....
                            keep the photo's coming....
                            cheers
                            Mike
                            • Nice work Thuppu.
                              I can only say that you can get at least 400kW from wheels with this turbo and E85. This was only with 2.3bar. You can go up to 2.9-3bar overboost with HX40S .
                              So dont worry about braking 600hp from crank barrier, more worry HOW to brake 700hp barrier.
                              I just run with E85 11.5 and 205kmh. This was with 2.1bar.
                              Audi UrS4 609hp/846Nm @ wheels
                              10.911@210, 1km 268km/h, 1mile 295km/h
                              FATS 2,30 sec
                              • are you thinking of doing anything with the brakes??....Rocco's got some nice bits for sale!!
