UrS4 2.2T Avant project
  • Thuppu
    • 4115
    Well, the spark plug thing hadn't anything to do with money saving. I had a brand new set of P0R's and NGK's on the shelf. Didn't had enough of brain for remember changing them though.
    I would be very disapointed if the final power is under 600... if I some day get all rolling properly.
    • kenax
      • Mar 2010
      • 85
      Ok..
      I'd stick to the F5DP0R and if there's problems, then the NGK.
      • prj
        • Mar 2010
        • 6308
        I think final power will easily be over 600hp.
        IDK about the comp wheel... it's your choice, I'll map what ever is on the car
        • Billman
          • 4129
          #634
          Originally posted by Thuppu
          I propably only smoothen down those dents a bit and re-balance the chaft, should be good that wise.
          It would raise flow and also become super laggy! Go straight to HX50.
          Go Holset or Go RS4
          • kenax
            • Mar 2010
            • 85
            Don't use the HX50, it's not a good turbo for this engine.
            Stay with the 40 Super, it's quite simply a really really good turbo. Next reasonable upgrade to 40 Super is the Pro52. But that's only when you want WELL over 700hp.
            • Thuppu
              • 4115
              No way it will be as laggy as HX50 if there is only few ~1mm dents on the some blades. Most of them is less. Propably not gona see any difference to before. I'm very pleased with the spool of the HX40S and I will stay with it. The comp upgrade was just a idea, they do "HX45Pro" hybrids and those are something like 750hp turbos with spool close to a stock HX40S.
              BTW got the new piston rings today, so now all parts is ready for the engine... exept the turbine shaft.
              • Billman
                • 4129
                #637
                You have to remove everywhere the same amount + the normal gap between impeller and housing....would be interesting to see whatever the outcome.
                Go Holset or Go RS4
                • Thuppu
                  • 4115
                  According to two turbo experts, its enough to only smoothen the charp edges and then balance it. No need to take off anything extra material from the blades.
                  • Thuppu
                    • 4115
                    Have been on holiday and have had a pause with the car... and now I broke my back and I'm on sick leave... But anyway, the bores was glazes for some reason, that was the reason for high oil consumption. Propably washed by fuel during a not so good map for the setup. Last week I got the cylinders re-honed and new rings fitted. The map should now be a ok safe map to drive untill we meet with Dmitri again.
                    Changed also a front control arm, the inner bushing was bad.
                    • Bram
                      • Aug 2006
                      • 2582
                      nice water jacketing. love it
                      • europeanme
                        • Oct 2005
                        • 3817
                        you've broke your what!!!...dude first the car and now your spine....crazy....
                        glad to see your making some headway with this Thomas....don't be disappointed with getting under 600 (even though it is unlikely you will) its all about the feel...."pub figures" are all well and good but if it drives like an old cow, that wouldn't be good....at least if it puts a smile on your face thats what its all about....
                        and as I work with large impellers for a living, you can trim them without a loss of performance but it might be a nice thing to keep as a spare...
                        keep those updates coming....
                        • prj
                          • Mar 2010
                          • 6308
                          Wow, I hope your back is not *too* bad.
                          Get well soon, and I will be following your thread, as I always have
                          • Thuppu
                            • 4115
                            No, nothing too serious. It's not the spine itself, the musles are cramping. Nothing a little rest and painkillers can't handle.
                            Mike, under 600 is not acceptable at any circumstances. Even if I propably will be sick scared to drive it.
                            • Billman
                              • 4129
                              #644
                              get well fast to continue . we want to see it run soon.
                              Go Holset or Go RS4
                              • V6quattro
                                • Sep 2008
                                • 949
                                Already know what spark-plugs you will use now?
                                1360kg/600Whp Avant 0-200km/h 9sec
