so that's 2 left and 2 right?
UrS4 2.2T Avant project
Well, in my opinion dual twins are too much bimmer look.
Edit. Hmm, ~50km to the nearest E85 fuel station. What size injectors would be enough to max out the HX40S with E85?Last edited by Thuppu; 7 June 2012, 14:24.
Well, it's very theoretically but let's have a go.
- 700hp capable turbo, that's at least 0,6kg/s airflow.
- Burning air to fuel at a ratio of 10 with E85 mixture with density of 780kg/m³ would need around 4500cc's per minute, divided over 5 cylinders is 900cc/min injector MINIMUM.
- Max mapping DC of 80% to have enrichment margin, make it 1200cc/min flow.
Of course a smaller injector could do combined with increased pressure delta over in injector by tweaking the FPR.
Originally posted by Topolini View PostDo you have more pictures of this car?
Exhaust still not finished but drove it today. My neighbours propably love mee.
Looks quite sharp in the image, but there is much rusty and rotten places on this car. I sure you that better ones has been broken to parts many times.
Thanks guys.
Collected all info about the technics, mods etc. so far.
Block:
- 82,5mm bored stock AAN block
- Pauter rods
- JE-pistons 82,5mm 8,5:1 CR
- CP lightweight 20mm piston pin's
- APR(replica) studs
- Machined water jacket
- 25-row oil cooler
- Engine mounts alu polyurethane(made by AnLe audifinns)
- Engine front mount 034 polyurethane/DIY
- DIY sump baffles
Head:
- Cams 7A exhaust cam, AAN cutted ex cam as intake cam
- Rosten high load springs and bottom retainers
- Stock INA lifters
- Lightly ported head
- Re-shaped ex- and intake valves
- Rosten adjustable ex cam gear and intake cam sprocket
Breathing:
- Tube exhaust DIY
- AAN intake manifold
- Tial MVR wastegate
- Holset HX40 Super Turbo
- 4" Downpipe
- 5" 100cell catalytic converter
- 3,5" Exhaust with Simons silencers
- 3" IC piping
- 450x300x76 cooler
- Aquamist HFS-3 water injection
Engine management:
- Motronic
- RS4 MAF
Fuel delivery:
- 2 x Bosch 044
- 2 x stock fuel filters
- Walbro 255LPH lift pump
- ~4,8 liter surge tank
- Mallory 4305M FPR
- 12x1mm fuel piping
- 1/2" and 3/8" steel braided teflon lines with pressed hydraulic fittings
- Bosch EV14 1000cc@4 bar injectors
- Custom "Motorsport" fuel rail
- DIY breather system with swirl pot
Ignition:
- 1.8T/TFSI coils
- Bosch F5DP0R plugs
- DIY loom
Driveline:
- SRE pressure plate, 4-puck sinter
- Fidanza lightweight alu flywheel
- 01E 6-gang gearbox
Suspension and brakes
- Koni sport shocks
- Weitec -40mm springs
- Front subframe bushings replaced with DIY alu/steel bushings/mounts
- Rear subframe bushings replaced with delrin bushes (made by bambridge S2forum)
- Front brakes S4 B5 30x321mm disc's with HP2 calipers
- Rear brakes stock
