UrS4 2.2T Avant project
  • Originally posted by Thuppu View Post
    I think this will be enough for the rear calipers. They have so little work to do, so I wont even use the second fitting point.
    Hell, save weight & don't even put the rotor on!
    "Nulla tenaci invia est via"
    • Originally posted by A1QSHIP View Post
      Haha! Your absolutely right.
      • All issues with the rear caliper mounts seems to be sorted out. The lower caliper fitting point was really tight fit. Had to grind a bevel on the "ear" and coudn't fit normal bolts. So I desided to use countersink bolts. Was quite easy to do the sinks with a hand held power drill and a countersink tool.
        Have to put a 2mm spacer behind the disc to get the offset right to fit the caliper. Can't move the caliper any deeper in.
        • May be fun to get those bolts out after a lot of use.
          • Why would you need to take them out? But I agree it can be a pita if you somehow need to do it.
            • I suppose the pads come out of the top so not a big deal. I was thinking of standard floating calipers.
              • Do you have a drawing with the main parameters of the adapter, could you show it?
                • Originally posted by Topolini View Post
                  I can sell you a kit, including a pair of adapters, pair of spacer shims to get disc offset right and the needed bolts.
                  • What would be the price for that kit Thomas?
                    • 75e + shipping
                      • Thomas,
                        lol you get more progressed than mine now.
                        wondering what's the disc size you're going to clamp the calipers on?
                        my plan is going to use front stock 314X30mm.i love the bracket.it looks so sweet.
                        2 upper drillig holes are for E-brake calipers mounted?
                        one of a few I5 from Asia.
                        • Hello pop,
                          I'm using 330x22mm discs
                          Yes, they are for future custom e-brake brackets.
                            Where i can find and buy the additional parking brake?
                              Here is some ideas: http://www.s2forum.com/forum/showthread.php?t=62733
                              • That sounds nice like a nice price for the kit, no chance that you can mount the caliper more in a "straight" or will it interfere with the handbrake caliper? You now me and my perfect alignments
                                Also, you have done the hand-brake caliper done you have to get back to me
                                1995 Audi S6 - AAN (~350hp)
                                2008 BMW 530xd (235hp)
