UrS4 2.2T Avant project
  • Thuppu
    • 4115
    And I finally found braided brake hoses for the rear. HEL's BMW E30 M3 rear to Brembo hoses. They are 320mm in lenght. Maybe little too much, but didn't find any shorter with those end fittings.
    http://www.ebay.co.uk/itm/121270294716
    • europeanme
      • Oct 2005
      • 3817
      Originally posted by Thuppu
      Thanks Mike, am I so predictable? Thats nice to hear, have you dynoed it yet?
      it comes with the territory Thomas...big power means big brakes...
      no not yet dude...I've had to do a bit of reworking of the turbo....I've gone smaller hotside to try and reduce the lag, 0.63AR....the tuner also had a spot of bother...found this in the hotside after it had wedged my compressor wheel!!...so with that I had the turbo stripped, checked and rebuilt with the smaller hotside....I'll let you know how I get on...
      have you ran you coilovers yet?...if and when you do, how do they feel??...
      Mike
      • europeanme
        • Oct 2005
        • 3817
        tell me what you want length wise and I'll get them made....I'm sure I can get them cheaper than that...
        • quattrostyle
          • Oct 2006
          • 6229
          Great stance
          • Thuppu
            • 4115
            Argh, now you tell mee. Already bought those.
            • ringbearer
              • Sep 2011
              • 176
              Nice job on everything. I like the rear shock setup. Even the green wheels.will be fun for a bit.
              • europeanme
                • Oct 2005
                • 3817
                sorry dude....
                • Thuppu
                  • 4115
                  sorry dude....
                  Don't worry Mike, next time then.
                  • Thuppu
                    • 4115
                    Mike
                    I know the feeling when you strip down parts and find strange bits that doesn't belong there. Good that you got it sorted out. Interesting to see results when you get there.
                    No, I havn't drive the car yet. They can be quite harsh on the road, but it isn't build soft comfort in mind...
                    • europeanme
                      • Oct 2005
                      • 3817
                      I only ask as I've been in coupe's with coil overs and I was very surprised how supple they were despite them being lowered....
                      remind me are your coilovers an off the shelf kit or a custom set up??....I thought I saw Bilsteins in there...
                        #1331
                        Don't forget the third nut. BTDT, that's why I mention it. Best wishes.
                        • Thuppu
                          • 4115
                          I would say this is custom setup. Bilstein shocks yes, front standard B8 sprints for the C4 chassis. The rear was some Volvo Bilsteins with H&R springs, don't know the exact model. Springs 6" 750lbs in front, 4" 150lbs helper spring. Rear 500lbs, helper maybe 100lbs..?
                          Don't worry, all parts are going for electro coating before final fit.
                          • Thuppu
                            • 4115
                            Waiting to get som small bits from the machine shop, then I'll bring a whole lot of bits to electro coating, rear brake adapters, rear top mounts, spacers, bolts, etc., etc.
                            In the mean time I started to plan the seat install and roll cage layout. I will propably fit the a-pillars like in the pic. Need to cut the lower corners of the dashboard and right flank of the glove box.
                            • andy10v
                              • 5996
                              This is getting rather extreme!
                              What are you mocking the roll cage up with?
                              Sold ABY-stock
                                Plastic water pipe?
