UrS4 2.2T Avant project
  • Thuppu
    • 4115
    Originally posted by Wrath
    That sounds nice like a nice price for the kit, no chance that you can mount the caliper more in a "straight" or will it interfere with the handbrake caliper? You now me and my perfect alignments
    Also, you have done the hand-brake caliper done you have to get back to me
    The idea was to mount the caliper higher up, stright, but these calipers can't be done so. The caliper fitting "ear" hit the hub carrier, can be seen in the posted pics. Also have to leave room for the e-brake caliper(and use it with stock wires). The upper control arm fitting eat most of the space.
    • krzysztofkabaj
      • Jan 2015
      • 36
      • Country: Poland
      #1307
      Thuppu, Got the same brake setup as Yours :
      Some time ago fitting front set of new brakes I meet the problem with disc - I used the same as Yo do. The diameter needs to be decreased to 354mm otherwise caliper blocked the disc.
      But in S4 C4 front columns such problem does not exist.
      • Wrath
        • Jan 2011
        • 779
        Interresting, but you don't have any e-brake in that setup I guess ?
        1995 Audi S6 - AAN (~350hp)
        2008 BMW 530xd (235hp)
        • Wrath
          • Jan 2011
          • 779
          I understand, but the idea and design is really really good thinking...
          • krzysztofkabaj
            • Jan 2015
            • 36
            • Country: Poland
            #1310
            Hydraulic hand brake instead of cable version.
            • Thuppu
              • 4115
              Recieved the brakepads today. Mintex brand, no racing pads, but hope that they are equal to OEM pads..?
              Front begins to be ready for testing
              • popdemonic
                • Dec 2007
                • 1304
                • Country: Thailand
                #1312
                Thomas,
                Mintex Redbox is just fine.it probably gives you some slightly squeaky Noise but who cares?
                one of a few I5 from Asia.
                • Thuppu
                  • 4115
                  Ok Pop, great to know. We will see next summer how they perform...
                  BTW, recieved the custom HX40 fully rebuild. Hope it last longer now...
                  Racing seats seems to be shipped, so they should be here in a week or so. Did also order racing belts, so maybe there is need for a roll cage now..?
                  • Wrath
                    • Jan 2011
                    • 779
                    Have used Mintex on stock calipers and they where good
                    • popdemonic
                      • Dec 2007
                      • 1304
                      • Country: Thailand
                      #1315
                      Oops That HX40 makes my 2871 looks like a tiny bits
                      • igor136
                        • Jun 2014
                        • 363
                        • Country: Croatia
                        #1316
                        I have Mintex. Howling like a dog.
                        1-2-4-5-3
                        • Thuppu
                          • 4115
                          I'm not afraid of sqeeking brake noise. Only hope they can take beating on track without loosing too much brake power. And would be nice if they last a couple of track days.
                          • Thuppu
                            • 4115
                            My friend did turn the slick tyres on the wheels. Was quite hard to get them seated properly, two of them did "bang" on at 5.5bar. Tyre size 250/650/18. Ready for the summerparty... hope nothing isn't ripped of at high speed cornering.
                            Did also recieve the seats. Not 100% pleased with the finish, lots of wrinkles on the vinyl. Have to see if a heat gun can smoothen them some. Still waiting on the belts...
                            • europeanme
                              • Oct 2005
                              • 3817
                              nice brakes T......I knew you would'nt stick with the older ones!!...
                              I've finally got your old CT working....
                              • Thuppu
                                • 4115
                                Thanks Mike, am I so predictable? Thats nice to hear, have you dynoed it yet?
                                Got the rear coils fitted today. Had to do a small extension to the top mount. DIY poly bushes and big washers holds it in place.
                                Lower mount, needed a bore from 10mm to 12mm and some nice thick "washers".
                                Have to lift the car some, because there isn't much more room for compress... Front is bad. Shorter strut and shock cartridge would have been nice.
                                Rear seems to be ok.
                                This is how the UrS looks now with this drop.
                                Rear wheel with @Brembo inside.
