UrS4 2.2T Avant project
  • A1QSHIP
    • Aug 2004
    • 975
    Originally posted by Thuppu
    I think this will be enough for the rear calipers. They have so little work to do, so I wont even use the second fitting point.
    Hell, save weight & don't even put the rotor on!
    "Nulla tenaci invia est via"
    • Thuppu
      • 4115
      Haha! Your absolutely right.
      • Thuppu
        • 4115
        All issues with the rear caliper mounts seems to be sorted out. The lower caliper fitting point was really tight fit. Had to grind a bevel on the "ear" and coudn't fit normal bolts. So I desided to use countersink bolts. Was quite easy to do the sinks with a hand held power drill and a countersink tool.
        Have to put a 2mm spacer behind the disc to get the offset right to fit the caliper. Can't move the caliper any deeper in.
        • dustovich
          • May 2014
          • 50
          May be fun to get those bolts out after a lot of use.
          • Thuppu
            • 4115
            Why would you need to take them out? But I agree it can be a pita if you somehow need to do it.
            • dustovich
              • May 2014
              • 50
              I suppose the pads come out of the top so not a big deal. I was thinking of standard floating calipers.
              • Topolini
                • May 2010
                • 37
                • Country: Russian Federation
                #1297
                Do you have a drawing with the main parameters of the adapter, could you show it?
                • Thuppu
                  • 4115
                  I can sell you a kit, including a pair of adapters, pair of spacer shims to get disc offset right and the needed bolts.
                  • Majorcina
                    • Jun 2013
                    • 1334
                    • Country: Montenegro
                    #1299
                    What would be the price for that kit Thomas?
                    • Thuppu
                      • 4115
                      75e + shipping
                      • popdemonic
                        • Dec 2007
                        • 1304
                        • Country: Thailand
                        #1301
                        Thomas,
                        lol you get more progressed than mine now.
                        wondering what's the disc size you're going to clamp the calipers on?
                        my plan is going to use front stock 314X30mm.i love the bracket.it looks so sweet.
                        2 upper drillig holes are for E-brake calipers mounted?
                        one of a few I5 from Asia.
                        • Thuppu
                          • 4115
                          Hello pop,
                          I'm using 330x22mm discs
                          Yes, they are for future custom e-brake brackets.
                          • Topolini
                            • May 2010
                            • 37
                            #1303
                            Where i can find and buy the additional parking brake?
                            • Thuppu
                              • 4115
                              Here is some ideas: http://www.s2forum.com/forum/showthread.php?t=62733
                              • Wrath
                                • Jan 2011
                                • 779
                                That sounds nice like a nice price for the kit, no chance that you can mount the caliper more in a "straight" or will it interfere with the handbrake caliper? You now me and my perfect alignments
                                Also, you have done the hand-brake caliper done you have to get back to me
                                1995 Audi S6 - AAN (~350hp)
                                2008 BMW 530xd (235hp)
                                2011 KTM 990 SMR - custom tuned (120whp)
