Well des, you have to try it. I was first thinkin of a setup like you are suggesting. But I think this setup is brilliant in all its simplicity. I'll say it again, when a roots doesn't work against pressure, it will spin freely and won't produce heat.
Lets say the supercharger flows 600cfm and the turbo flows 900cfm. The turbo gets 600cfm from the supercharger and then the pressure between supercharger and turbo has drop to zero. When the pressure drops below zero(to vacuum) the one-way valve starts to open up and the turbo gets the last 300cfm thru the valve.
