UrS4 2.2T Avant project
  • quattro-nick
    • Sep 2012
    • 1746
    • Country: Belgium
    #1486
    nice video
    do you know on which rpm and boost the valve goes open?
    TWINCHARGED power,zero lag
    AEM W/M injection
    • diesel des
      • 3896
      #1487
      What force is required to open that valve? Is it spring loaded?
      • quattro-nick
        • Sep 2012
        • 1746
        • Country: Belgium
        #1488
        probably a light feather to close.with the compressor boost the valve closes and when the suction of the turbocharger is greater than the flow rate of the compressor, the valve opens
        AEM W/M injection
        • Thuppu
          • 4115
          Nick, no I don't know, but when I get a pressure gauge fitted that measures the intake pipe, it will give some info.
          Des, it's just a gravity- and pressure controlled flap, no spring. It just opens of vacuum/airflow when the turbo outflows the supercharger.
          • quattro-nick
            • Sep 2012
            • 1746
            • Country: Belgium
            #1490
            did you solved the fuel cut problem thomas?
            i realy like your twin setup mate,maybe i build this to in the future on my car but I fear I have no room for the compressor because I still have the radiator next to the intake
            i'm curious for the dyno results
            AEM W/M injection
            • Thuppu
              • 4115
              Seems to be the VEMS fuelpump output failing. I have just bypassed it for now. Don't know who will repair it or change the output..?
              • quattro-nick
                • Sep 2012
                • 1746
                • Country: Belgium
                #1492
                why not just use a relais to give power for the fuelpump and injectors which closes with the ignition on? i'm sure this will work
                vems can still make a fuel cut by injectors if necessary
                AEM W/M injection
                • priba
                  • Mar 2015
                  • 108
                  • Country: Croatia
                  #1493
                  Originally posted by Thuppu
                  Small vid of the one-way valve action.
                  https://www.youtube.com/watch?v=7hT_F-KeJDM
                  ohhhh those sounds
                  Thomas ... mass respect for the build
                  I realy admire your manufacturing skils ... and kinda jealous on your garage tools
                  took me a while (few days) to go trough topic ... got some good laughts, too
                  wanted to tell you about fuel lines ... I used nylon when was swaping the engine
                  it's much easier to route them trought tight openings used for oem fuel lines
                  I used original metal lines from urs6 only for connection to filter and tank
                  lines are 10x1mm cross section but they have different sizes, of course
                  that 3rd plastic line is for lpg
                  similar story with flexibile brake lines for calipers ... there is a guy in my town working with hydraulics and he makes custom brake lines
                  those are teflon core with inox mesh reinforcement on the outside
                  maybe you could find someone to make you those things next time ... works for all liquids and oil lines too
                  keep up the good work
                  • Thuppu
                    • 4115
                    Thanks Marko.
                    Did a small update to the breather. I have used only the block breather, no outlet in the head, and that have caused oil to spit out in hard launches because the oil in the sump are forced to the rear... Well, I did add a outlet on the valve cover and routed it to the oil separator. Needed to weld on a extra fitting on it. Used AN10 fittings and hose. A parts store 100m from home started to sell AN-fittings and weld bungs, so no need to order from ebay anymore. Good thing is that they are also cheaper than ebay ones.
                    Did also put a new return line to the sump. Old hose was just some basic air hose, that seems to not hold against oil very well. Now it's little overkill.
                    • AndyP
                      • 6049
                      I wanted to put the cam cover breather on top like that, but the stroker engine is taller and it hit the bonnet
                      • Thuppu
                        • 4115
                        Yea, not much clearance left between the fitting and bonnet in this setup either.
                        • quattro-nick
                          • Sep 2012
                          • 1746
                          • Country: Belgium
                          #1497
                          any update about the fuel cut thomas?
                          AEM W/M injection
                          • Thuppu
                            • 4115
                            Well, no cuts anymore when the pump control is bypassed.
                            • diesel des
                              • 3896
                              #1499
                              I had the same breather problems with oil being forced out the block when accelerating hard. I just use the head as a breather now. I drilled the pipe in the rocker cover and use that as a vent.
                              • andy10v
                                • 5996
                                Nice swirl pot and drain.
                                Stock rear vent surges under launch, block vent surges under hard right hand bends.
                                I am going vent purely from the cam cover, drilled the tube to use as a vent, into swirl pot with drain to sump, then vent from swirl pot to catch tank, fingers crossed this works.
                                Sold ABY-stock
