UrS4 2.2T Avant project
  • europeanme
    • Oct 2005
    • 3817
    dude thats tight.....not tight as in good but tight as in not much room....
    I was looking at putting it in that area, as my oil cooler is going somewhere else but then had visions of something 'bouncing' down the road ripping it off and engine giving up!!.....
    • Thuppu
      • 4115
      Ok, seems that I waste my time with the air-intake. Heard that you need to protect the intake from the wind/draught when you drive, otherwise it can effect the MAF readings... Well, it's something I couldn't think of earlier. Isn't the amount of air the engine sucks a lot greater than any wind flow..?
      Edit. Maybe I should put the MAF on the pressure side after all?
      • prj
        • Mar 2010
        • 6308
        I think your intake and MAF will be just fine.
        • Thuppu
          • 4115
          Ok, I leave it like that. Still have to add the by-pass- and N75 inlets...
          • prj
            • Mar 2010
            • 6308
            Btw, I think I can just come over for a long weekend (Fri-Sun) once you need me to.
            There is a plane going right from my little town to Vantaa airport, and it's only 50 minutes
            The only other thing that worries me, is that it's 400+km between Vaasa (or wherever you are located) and Helsinki.
            • Thuppu
              • 4115
              Some small updates... 4 inch downpipe fabricating...
                Any pics of the wastegate pipe and routing?
                • Thuppu
                  • 4115
                  No, it's not finished yet. Maybe tomorrow, I'll put som pics when I get it ready.
                  • europeanme
                    • Oct 2005
                    • 3817
                    Thomas, I never said it was a waste of time, just that it was tight...it does look like it is out of the way I just meant there isn't much room....
                    as for putting the MAF on the pressure side, I have heard that as well.....anyone got any other ideas on this matter?....
                    the 4" DP is awesome...
                    • prj
                      • Mar 2010
                      • 6308
                      The RS4 MAF is too big for the pressure side.
                      The 2400 kg/hr (read 800+hp) 3" custom concoction we're working on with Pro-M will be just right for it though. Will come in a nice 3" tube, and it's 100% meant to be used on the pressure side.
                      Unfortunately not ready yet...
                      • Thuppu
                        • 4115
                        No worry, I wasn't refer to your comment.
                        • europeanme
                          • Oct 2005
                          • 3817
                          I knew that.....
                          • europeanme
                            • Oct 2005
                            • 3817
                            before august?...
                            • Thuppu
                              • 4115
                              DP finished:
                              DP and WG-pipe tight fit:
                              Not too low down..?
                              • prj
                                • Mar 2010
                                • 6308
                                before august?...
                                Can't promise anything. It'll be done when we have a GT35R car running on it and everything runs smoothly.
