this rods are fine.. it is not damage on rods , they are heat from bearing.
UrS4 2.2T Avant project
Originally posted by pasbogdan View PostDid the bearing spin in the rod?Tighten the rod cap and ceck for roundness.
Regards,
If someone has a Aron's rod for sale, please make a offer.
Originally posted by Thuppu View PostAll rod weights was between 592-593g. All pistons 303-304g. Total weight including pin, rings and clips 1kg.
Got the waterjackets done to the blocks, thanks to my friend. Tomorrow the engine shop takes the other one for boring and they mill the deck clean also.
Got also Rusty's billett coolant pipe for the block. Really nice quality!
Head resurfaced.
Ordered some parts for the block, new check valve, oil squirters, oil pressure sender, oil temp sender and the breather assy.
Thanks. Well, actually the thanks goes to my work mate, he did great job with them.
Shipped out the crank(damper, flywheel + other needed parts) this week for balancing. Propably takes a week or two before I get them back, then the assembly can begin.
Got the bottom end from the machine shop. Crank is balanced to zero with bobweights, added damper and flywheel and also balanced to zero. Funny, didn't find any balancing bores on the flywheel and pressure plate. Maybe they are at zero from the factory..? Fidanza alu-flywheel and SRE-pressure plate.
Cleaned and painted the block when I waited for some parts...
Finally today the ordered parts arrived, new breather assy, oiltemp sensor to the pump, all oilsquirters and the check valve.
Should recieve new CP-piston pinns this or next week, and must order the oilpressure sender and oilpressure switch.
