UrS4 2.2T Avant project
    Don't you need pipe work between the maf and air filter?
    Thought you get bad readings with a filter directly on the maf
    • Thuppu
      • 4115
      This is a RS4 MAF. Should work nice with filter directly fitted on.
      • prj
        • Mar 2010
        • 6308
        Would be nice to have a pipe between MAF and filter
        But if you always use the same type of filter, this will be taken account in calibration anyway.
        That 4" inlet on the turbo is funny considering the size of the comp wheel.
        Looking good though...
        • Thuppu
          • 4115
          Yea, remember you spoke earlier something of fitting the filter straight to the MAF..? Anyway there is not too much space. Propably the filter gona hit the belly plate now already. I can cut a few cm of the piping though.
          • prj
            • Mar 2010
            • 6308
            I have calibrated plenty of setups where people fitted the filter straight to the MAF. And I know there is not much room. It's not 100% ideal, but the MAF does have a mesh and a tube, so that it should operate pretty much correctly.
            As long as you don't change the setup around afterwards, it'll be fine.
            Working on a 3" blow-through solution with Pro-M, but it'll be a while until it's ready for prime-time.
            Don't worry, we'll get it mapped
              #366
              Jeepers, after putting all this effort into this engine, you are definitely due better luck than the last engine.
              Great thread and photos, thanks for sharing.
              The car’s future is assured in your ownership.
              Best of luck with it.
              • Wrath
                • Jan 2011
                • 779
                Really nice build, Like this alot !
                just a question? Why do you even use a MAF ? What engine management system do you use?
                1995 Audi S6 - AAN (~350hp)
                2008 BMW 530xd (235hp)
                • Zoig
                  • Sep 2008
                  • 555
                  • Wrath
                    • Jan 2011
                    • 779
                    I see, just saw some VEMS gauges and thought you played with the same EMS as I
                    • Billman
                      • 4129
                      #370
                      Yes, I also thought that you used VEMS.
                      Go Holset or Go RS4
                      • Thuppu
                        • 4115
                        Yes, I'm using stock Motronic. Only VEMS wideband/ex-temp gauge...
                        • Thuppu
                          • 4115
                          Got a used plug&play fuelrail. Had to tune it up a bit, machining the text on it. It sure does 20hp more. Also bored the bungs from 5mm to 8,5mm.
                          • rs200
                            • May 2009
                            • 1398
                            • Home: Croatia
                            #373
                            long time I want to ask.. did that "motorsport fuel rail" , mean better performance or what?
                            what did you get with them? how much is there better than stock one?
                            tnx
                            • Thuppu
                              • 4115
                              I meant the "Motorsport" text does a psychologic + 20hp. The fuel rail itself does like zero hp, but I want to put bigger fuel lines all over, also better flowing FPR so thats why I change the rail.
                              • Wrath
                                • Jan 2011
                                • 779
                                Nice, psychologic is like 30 brake horse power at least
