Sounds like all pocket bikes and minibike that was popular a couple of years ago... everything needed to re thighten. Agree totally on the price issue... but how about this cheap as chips tig welder with a proper torch and hose package? Should last a while...
UrS4 2.2T Avant project
The spare parts, torches, nozzles etc. is really sheap for these machines on ebay so no need to buy a expencive torch. I don't see any trouble with the torch that came with the machine.
Fitted the solid front subrfame bushes today.
BMW 740iA e38 - ProjectComment
Does the torch have a flexible neck?Comment
Are the fittings the same as ESAB or Kemppi?Comment
The old exhaust is sold...
Some small updates. Got the other waterline for the wastegate today. Had to do a custom fitting for the block water-intake, but it worked out nicely.
Also tested to do some 3" to 4" stainless exhaust reducers. Pressed in a 300T bending press.
Well, I look't at the torch better today, and yes, it has a flex neck after all.
It's some kind of rubber cover with a flex inside.
It looks like this:
I really love this thing! Welded flanges for my turbo oil return line today, and it's so smooth to weld with it, and you can weld really small things with it with high precision. Stainless braided teflon hose is pressed on the hose fittings.
All exhaust parts has been collected, exept for the cat. It has seized at the toll customs...
Simons 3,5" mufflers.
Also recieved a new oil cooler, 25 row.
I have a couple of brand new 3,5" 90 degree bends, and a bunch of 4" used bends, plus some 3" for the IC pipings. Have to cut them with a angle grinder, I don't have any better solution for the job.
Used 4" and 3":
0-200km/h 9sec
