UrS4 2.2T Avant project
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    #256
    We have had this discussion on another thread. Looks like idle has not much relevance than what the oil pressure does as rpm rise. My engine fully rebuilt has 1.4bar with 10w50 fuchs Titan, and gets swiftly to 4bar as early as 2000rpm. A lot of fully rebuilt engines from members are like that.
    I am changing the sender and switch as well tomorrow to verify.
    Just before the rebuild and with 100k kms from the previous rebuild I was having 2 to 2.5bar on idle and using the same oil pump ( now refurbed as well). But we noticed that Ola had a slightly crushed check valve previously. Don't know if it was causing the higher pressure reading though.
    I will report in the weekend of how the pressure behaves.
    sent using Android
    • Thuppu
      • 4115
      Originally posted by ifa
      Measure pressure with mechanical gauge. 1,5 bar sounds too low for re-build engine.
      Yes, I have done that. Idle pressure is almost same as on the stock gauge, on high rpm's the stock gauge shows about 0,5 bar to low.
      • europeanme
        • Oct 2005
        • 3817
        Originally posted by Thuppu
        Didn't have anything to do in the night shift last week when the laser-machine was cutting for several hours so I decide to mod the stock wastegate a bit. Didn't take pics before so you can't see the difference, but I hope it will flow better than stock. It was not possible to increase much the size of the vent without changing the valve and ring, only 34mm -> 35mm but I made some other improvements(I hope ) in the shape...
        thats what i like to hear Thomas, a productive night shift!!...:mischeif:
        • Thuppu
          • 4115
          Haha, Mike you know, you have to do something or you fall in sleep.
          Soon engine start, have only to fit the radiator and IC. Just bought a can of Valvoline VR1 Racing 5w-50 oil. Propably the hot oil pressure wil be 0,5-1bar higher than with the old oil, just like before when I changed the oil. Well, I really hope the knockin noise is gone.
          • europeanme
            • Oct 2005
            • 3817
            after 3am was the worse bit for me....
            I hope you get it sorted....
            • Thuppu
              • 4115
              Yea, 4-5 is sick for me. Mike, how does your project progress?
              • europeanme
                • Oct 2005
                • 3817
                i didn't say it got easier after the 3am "deadzone"...and that rolled on til hometime at 6
                well i have sorted a clutch out...hopefully....and then balance..early days...just gathering parts....i'm watching your project at the minute...
                • Thuppu
                  • 4115
                  I was wrong, it was not the lifter noise. Seems that I need to strip the bottom end.
                  Havn't had time to do anything to the car at the previous week. Just changed the bimmer also, and the exchange has got all attention... Pic of the new ride: Klick!
                  • prj
                    • Mar 2010
                    • 6308
                    Grats on the new ride...
                    Oh well.
                    • DS2
                      • 80
                      • Home: Jordan Current: Finland
                      #265
                      congrats on the "new" car
                      • Thuppu
                        • 4115
                        Thanks guys!
                        • Bram
                          • Aug 2006
                          • 2582
                          like your new ride mate
                          • Thuppu
                            • 4115
                            No wonder why the engine had a little strange noise... maybe the oilpressure wasn't enough after all? :corey:
                            • TimE-J
                              • Jul 2009
                              • 1292
                              That's really bad luck, what's your next step? How badly damaged is the crank?
                              96 S2 aby Coupe. Rebuild Project
                              96 mk3 golf tdi daily.
                              • A80Avant
                                • Sep 2005
                                • 10873
                                • Country: Greece
                                #270
                                correction,
                                just noticed that you were seeing 1.5bar warm and 3.5-4bar on higher revs.
                                that cannot be the only reason for the damage and the noise.
                                other cars have similar pressures, esp on idle and run ok.
                                could there be a blockage in the oil feeds somewhere?
