UrS4 2.2T Avant project
  • Thuppu
    • 4115
    Originally posted by quattro84
    Please add the partnumbers for future references.
    035103157B Oil squirters
    077103175B Check valve
    035919521B Oil temp sensor
    054103129 Breather assy
    Still have to order these:
    035919561 Oil pressure sender
    056919081 Oil pressure switch
    074103179 Adapter M16x1,5 -> M10x1
    Edit.
    Recieved the new piston pins today. Shipped last friday from US and today here, really fast. Also Freddy at CP-Pistons was a really nice and helpfull guy.
    Comparison pic, CP vs. JE pins:
    • Thuppu
      • 4115
      Started the official engine assembly yesturday. Have gapped rings and done some other small things. These takes time, and I work on evening shift this week so it always interrupts my time...
      Hate to put updates without pic, so lets put one like this of build materials.
      • Thuppu
        • 4115
        The breather assy seemed hard to fit without destroying it, so I made a special tool wich helped a lot to fit it properly.
        Removed all sharp edges of the pistons, also the sides of the valve pockets.
        Piston ring gaping in progress... First ring 0,45mm, second 0,50mm, oilrings 0,40mm.
        Pistons ready to go...
        • Thuppu
          • 4115
          The bottom end begins to be assembled.
          All rod neck clearenses was ~ 0.050mm.
          • Melber
            • May 2009
            • 36
            • Country: Russian Federation
            #335
            Tell me what the torque at the rods(H-profile) bolts ?
            The same will soon be to assemble ....
            • Thuppu
              • 4115
              I did use 55ft/lbs(74Nm) with motor oil. 50ft/lbs(68Nm) is enough with ARP lube.
              • Melber
                • May 2009
                • 36
                #337
                Ok, thank you!
                • Billman
                  • 4129
                  #338
                  what is this thing in the water plug?
                  Go Holset or Go RS4
                  • Thuppu
                    • 4115
                    It's a external block heater for the cold winters.
                    Little more progress:
                    • J_ones
                      • Feb 2011
                      • 44
                      Looks good indeed, only couple of things more and you'll pass me
                      Which side up did you put the Kalskes oil pump gear? There are these little... viisteet on the other side, what they're called in english, don't know.
                      Porsche 951 '87
                      • Thuppu
                        • 4115
                        Viiste = bevel. I did put the bevel face down, like the orginal gear. Here is the new gear fitted in the housing:
                        Joni, did you get your clutch housing yet?
                        • J_ones
                          • Feb 2011
                          • 44
                          Thanks!
                          No, I didn't. Lets hope it'll arrive soon. Of course I'll post some pics, you'll notice
                          Porsche 951 '87
                          • Thuppu
                            • 4115
                            Today I officially started the fuel line uprating. Removed the lines and fuel filter from the engine bay and planned the bottom lines replacement. The old lines seems quite rusty and knackered. New lines gona be 12x1mm stainless piping.
                            • europeanme
                              • Oct 2005
                              • 3817
                              any reason why you cannot re-locate the fuel pump?...give you a little more room in the engine bay...for bigger turbos!!...
                              • Thuppu
                                • 4115
                                If you mean the fuel filter, then yes, I'm going to re-locate it somewhere. Propably in the trunk. About the fuel pump I'm not sure yet. I have a 044 pump ready waiting and I ordered the basket assembly to fit it in the tank, but have also been thinking of a surge tank and external dual 044's...
                                Here you can clearly see how the fuel filter is stock located. It's quite a hot place, and if you get a fuel leak it's bye bye then.
                                Mike, seeing something yours?
