UrS4 2.2T Avant project
  • RichLV
    • Mar 2015
    • 872
    • Country: Latvia
    #1831
    If it isn't your daily, then no hurry.
    Pity though. These are stock pistons right?
    • Spyform
      • Mar 2016
      • 288
      Originally posted by Thuppu
      Your right. Now I have to make another engine, before there was no hurry.
      One thing that i didn't like about your 2.2t engine, that one more block is dead
      Audi S6 C4 2.2T Quattro 1997, full rebuild....
      Audi A5 Sportback V6 2.7 TDI 2011
      Volkswagen Phaeton V6 3.0 TDI 2009
      • Thuppu
        • 4115
        Have only one drivable car atm, my daily, and my wife likes it. So I have to put together another one quite fast.
        Yes, stock pistons.
        • quattro-nick
          • Sep 2012
          • 1746
          • Country: Belgium
          #1834
          thomas,maybe is the supercharger the problem for your turbo damage.the compressor wheel might not stand the supercharger pressure.
          what type of bearings has the turbo?
          TWINCHARGED power,zero lag
          AEM W/M injection
          • Thuppu
            • 4115
            It's a standard journal bearing. I did run the stock hx40 twincharged for quite long time without issues.
              I have a couple of good sets of stock pistons Thomas
              • Thuppu
                • 4115
                Thanks Alex, I think I also have 3 sets of spare stock pistons.
                  of course
                  • hammer
                    • May 2008
                    • 242
                    • Country: Austria
                    #1839
                    A friend of me has had the same problem. Its not a mapping problem, this happens when clearance pisten to bore is no more correct(oval)
                    Gesendet von meinem PLK-L01 mit Tapatalk
                    • Thuppu
                      • 4115
                      That could be a potential cause. After all, the piston to bore clearance was on the bigger side(of factory spec) and I did only hand hone the bores when I put together the engine. So for sure they have been oval, and also some taper.
                      • Dima ABY
                        • Sep 2013
                        • 183
                        • Home: Ukraine Current: Spain
                        #1841
                        Plus on low rpm if pistons have load they tend to twist.Supercharger may colaborate this.
                        Just the mechanical theory.
                        Waiting for a next episode of your Urs4 2.2t avant project.Hehehe
                        Best regards!
                        • diesel des
                          • 3896
                          #1842
                          It's hard for me to see as I'm just using my phone but isn't the damage to the piston just due to the weak (at this power level)stock pistons melting or breaking down? I'm sure the ring land has collapsed and the cylinder was also damaged? Get some fcp forged pistons. I have some for my stroker urq and they seem good size and quality. Not too expensive too.
                          • Thuppu
                            • 4115
                            Yes, a nice set of new FSR pistons would be nice. I have a kit of JE's but I would need one new as the piston pin hole is slightly damaged due broken pin. I think it could be possible to order one piston. But then one piston, new ring kit and new piston pinns... We are not far away from a full JE piston kit price wise.
                            Maybe just now it's time to finally put together the stroker.
                            • diesel des
                              • 3896
                              #1844
                              Do it!
                              • Thuppu
                                • 4115
                                Was in the garage for a while in the evening, drawing lots of what engine to put together. Decided to build a second ghetto engine, now even ghettoer than the last one. No need for any machining etc. so fast and easy to finish. Good thing with this is also that I can safely experiment with my M112 and K31, get everything working properly and then trow in the properly build stroker engine.
                                Some texture on the cylinder walls...
                                Had a crank laying on the shelf that needed some care.
                                Special damper with an extra pulley. Centered it in the lathe, and will mig weld it at work tomorrow.
