UrS4 2.2T Avant project
  • TAXIst
    • Jul 2015
    • 28
    • Country: Russian Federation
    #1876
    perfect
    • quattro-nick
      • Sep 2012
      • 1746
      • Country: Belgium
      #1877
      are you going for single or dual plenum intake?
      TWINCHARGED power,zero lag
      AEM W/M injection
      • Thuppu
        • 4115
        Originally posted by A1QSHIP
        Clever one you! Well done.
        Very good video here: https://www.youtube.com/watch?v=cgnB4bmodv4 But I think he's making it from 2mm aluminium which will mould easier. Made maybe 6-7 stacks that didn't turn out nicely. The most important thing is the heat.
        Nick, will go with a dual plenum IM.
        Edit.
        Main plenum would look like this:
        • Thuppu
          • 4115
          Some weldings to do...
          • Majorcina
            • Jun 2013
            • 1334
            • Country: Montenegro
            #1880
            Oh man,this looks awesome!
            Poslato sa G7-L01 uz pomoć Tapatoka
            • V6quattro
              • Sep 2008
              • 949
              I'm absolute no expert in manifold fabrication but is it possible that the small opening will cause a pressure drop or a reduction for the airflow? Looks nice though!
              1360kg/600Whp Avant 0-200km/h 9sec
              • Thuppu
                • 4115
                Got info from Repo how to do it.
                • V6quattro
                  • Sep 2008
                  • 949
                  Then i said nothing
                  • Thuppu
                    • 4115
                    • quattro-nick
                      • Sep 2012
                      • 1746
                      • Country: Belgium
                      #1885
                      very nice thomas,soon i'm gonna build also my own dual plenum with the same principle
                      i was planning to make first a hobby flow bench to see if my manifold flows different(better) than a origional,will see.
                      AEM W/M injection
                      • diesel des
                        • 3896
                        #1886
                        Nice manifold and cute cat!
                        • Thuppu
                          • 4115
                          Thanks. Got some weldings done today, and could fit the throttle body pipe. Quite tight fit, also the supercharger 4" inlet pipe will take some space...
                          • diesel des
                            • 3896
                            #1888
                            Nice. Tight spaces to weld in.
                            • Thuppu
                              • 4115
                              Bought a gas lens for the torch, and it feels better now. Can also keep the electrode longer, so you can see it better and can go in deeper corners. But I still will need a lot of practice to weld ally, it's really hard to get it good and nice.
                              • grundey
                                • Aug 2005
                                • 125
                                • Country: Latvia
                                #1890
                                On aluminum I don't feel much difference gas lens or standart tig setup, maybe the weld bead looks a little more shiny with a gas lens.
                                Welded with standart tig setup
                                The same machine but with a gas lens
                                Most of the time I use a gas lens because it makes my torch much shorter and it is easier to get in tight spots.
                                On aluminium I use tight fit-up to get nice looking weld bead.
                                Team RS
                                Grundey Intake
