UrS4 2.2T Avant project
  • Few months gone. Nothing big happend here, have been quite busy with other things. But always something small done... like getting ideas and collecting parts.
    • No More synchro issues then
      Sold ABY-stock
      • what gear is that? first and second?
        TWINCHARGED power,zero lag
        AEM W/M injection
        • Yes, it's 1-2 gears with custom ratios. 1st is 2.80 and 2nd 1.82. Dog engagement should give slight faster shift than syncro. Also shaft is thicker with chevy spline.
          • Originally posted by Thuppu View Post
            Slightly? If you get it perfect I turns into a f***** rocket
            1360kg/600Whp Avant 0-200km/h 9sec
            • Supercharged down low torque, horse head size turbo, and now aided gearing... I guess bad 1/4 mile times is then caused by the driver, haha.
              • Recieved some more parts for the transmission today...
                • Small ongoing project(oh really again ), shifter thingy... first proto... Shall see if it's workin properly some day. Going to use cable links.
                  https://www.youtube.com/watch?v=vYpQB68enZY
                  • Interesting, do you have any pictures of the mechanism?
                    Sold ABY-stock
                    • Nice ! Are you gonna build neutral gear release lever? I mean lever that you pull and push shiftstick to shift neutral no matter what gear is in. It could be useful but not necessary
                      • Originally posted by andy10v View Post
                        No, not yet. I propably have to modify the switch plates some, to get the gear change work properly. Have to get the cable links first...
                        Propably not, it would make it more complex and I like to keep it simpple. Should work like an motorbike gerabox. Only thing could be a lock for the reverse gear, so you don't try to grind it on on the move.
                        • i like your shifter thomas but i think you have no longer a good feeling in the gearshifter when you are shifthing the gears and there is something wrong
                          AEM W/M injection
                          • Nick, yes your right. It can be a problem with the synchro gears. For dog gear it's just the better the faster the change is. But as I still will have synchros in 3-6 there can be some difficulties with too fast shifts.
                              Yes please!!!!
                              Go Holset or Go RS4
                              • Main lever has push/pull hooks which rotate the shaft with 2 discs that act as cams to position the 2 rocker arms that will cable or rod actuate the selector?
                                Sold ABY-stock
