UrS4 2.2T Avant project
  • Thuppu
    • 4115
    Few months gone. Nothing big happend here, have been quite busy with other things. But always something small done... like getting ideas and collecting parts.
    • andy10v
      • 5996
      No More synchro issues then
      Sold ABY-stock
      • quattro-nick
        • Sep 2012
        • 1746
        • Country: Belgium
        #1953
        what gear is that? first and second?
        TWINCHARGED power,zero lag
        AEM W/M injection
        • Thuppu
          • 4115
          Yes, it's 1-2 gears with custom ratios. 1st is 2.80 and 2nd 1.82. Dog engagement should give slight faster shift than syncro. Also shaft is thicker with chevy spline.
          • V6quattro
            • Sep 2008
            • 949
            Slightly? If you get it perfect I turns into a f***** rocket
            • Thuppu
              • 4115
              Supercharged down low torque, horse head size turbo, and now aided gearing... I guess bad 1/4 mile times is then caused by the driver, haha.
              • Thuppu
                • 4115
                Recieved some more parts for the transmission today...
                • Thuppu
                  • 4115
                  Small ongoing project(oh really again ), shifter thingy... first proto... Shall see if it's workin properly some day. Going to use cable links.
                  • andy10v
                    • 5996
                    Interesting, do you have any pictures of the mechanism?
                    Sold ABY-stock
                    • NakSu
                      • Jul 2013
                      • 45
                      Nice ! Are you gonna build neutral gear release lever? I mean lever that you pull and push shiftstick to shift neutral no matter what gear is in. It could be useful but not necessary
                      • Thuppu
                        • 4115
                        No, not yet. I propably have to modify the switch plates some, to get the gear change work properly. Have to get the cable links first...
                        Propably not, it would make it more complex and I like to keep it simpple. Should work like an motorbike gerabox. Only thing could be a lock for the reverse gear, so you don't try to grind it on on the move.
                        • quattro-nick
                          • Sep 2012
                          • 1746
                          • Country: Belgium
                          #1962
                          i like your shifter thomas but i think you have no longer a good feeling in the gearshifter when you are shifthing the gears and there is something wrong
                          AEM W/M injection
                          • Thuppu
                            • 4115
                            Nick, yes your right. It can be a problem with the synchro gears. For dog gear it's just the better the faster the change is. But as I still will have synchros in 3-6 there can be some difficulties with too fast shifts.
                            • Billman
                              • 4129
                              #1964
                              Yes please!!!!
                              Go Holset or Go RS4
                              • andy10v
                                • 5996
                                Main lever has push/pull hooks which rotate the shaft with 2 discs that act as cams to position the 2 rocker arms that will cable or rod actuate the selector?
                                Sold ABY-stock
