Ok, so the fuel/IAT correction will be always in use... I remember last time on dyno the tuner was astonished that suddenly the engine started to go lean in the upper end. We was thinking about the fuel temps, tank and pumps was really hot. But it may be this setting that started to take over..? This is factory setting, I havn't touched it because I was thinking it's just for engine start(heat soak adjusment). And now I have had lambda correction up to the redline so it hasn't gone lean even at 100C IAT.
I think I will set the correction to zero and take few dyno runns with the lambda off and see how it behaves.
