UrS4 2.2T Avant project
  • da_trem
    • Mar 2008
    • 45
    If the motor isn't knocking on both types of fuel(same ign. map), why then is it more powerful with ethanol?..isn't ethanol less "energic" than petrol?
    ..or is it that there simply more boost added to the ethanol tune?
    1996 Audi S6, VEMS, S362.
    • Thuppu
      • 4115
      I don't know why, one thing can be that ethanol cools down the combustion. According to kenax there is a ~5% gain when switching from E98 to RE85 without touching the ignition and boost. Of course you have to tune the fuel map to suit the 85, something like +30%.
      • prj
        • Mar 2010
        • 6308
        Because ethanol contains oxygen.
        Also ethanol cools down the air when evaporating.
        Thus there is much higher cylinder charge with ethanol at the same boost level.
        • da_trem
          • Mar 2008
          • 45
          Ah! that explains it! ...oxygen.
          Thanks Dimitri!
          • Thuppu
            • 4115
            Fuel delivery
            Spark plug check after 1700km...
            Really can't tell of the color how the filling is, about 700km driven with the new IM...
              Looks like you are a building a Jihadi wagon
              Panthero CoupƩ quattro 20vt
              Indigo ABY coupƩ
              • Thuppu
                • 4115
                Now when you say it, there is of course a chance to see it that way.
                • Thuppu
                  • 4115
                  Filled up the tank from an other station and now propably got some "winter" mix e85, engine started to run pig rich on wot, lambda droped from 0,79 to 0,73. Well, decided to change the turbo now and see if it compensates the AFR... Lamba rised to 0,77 with it. Seems to flow some more, and spool starts about 300rpm higher up.
                  Did also fit some safety equipment in the cockpit
                  • Wrath
                    • Jan 2011
                    • 779
                    Earplugs and fire extinguisher !
                    1995 Audi S6 - AAN (~350hp)
                    2008 BMW 530xd (235hp)
                      Originally posted by Thuppu
                      Are you sure it's big enough Thomas?
                      We need vids!!!
                      Indigo ABY coupƩ
                      • Rocco
                        • Aug 2007
                        • 6393
                        • Country: Spain
                        #1061
                        wheel loader“s turbo
                        RED Mitsubishi Lancer Evolution VI TME nĀŗ 16 of 250
                        BLACK Mitsubishi Lancer Evolution VI TME nĀŗ 189 of 250
                        • Thuppu
                          • 4115
                          Alex, the turbo outside measures are exactly the same as before, only internals are a bit bigger. This is a ~750hp turbo. Nice to see how stock pistons holds up. They should hold though.
                          Wrath, earplugs are nice when you have to drive a lot on highway. This isn't exactly a silent car... ask Dmitri. You also never know when these hit fire, burning hot turbo and a leaking oil- or fuel line and you have a rolling torch. The insurance do not cover everything you have put and done on the car, even that the car itself has almost zero value.
                          • Laaf
                            • Oct 2010
                            • 275
                            When speaking on the phone last summer to Dmitri, he had to ask Thomas to pull off the road to be able to speak to me
                            • Wrath
                              • Jan 2011
                              • 779
                              Thomas, I know just thought it was a good looking image But you can always get a special Insurance that will cover the car“s expense but then that would be so high you get nightmares Have a fire extinguisher as well but no earplugs
                              • K Simmonds
                                • Dec 2007
                                • 7627
                                I carry a small fire extinguisher in my S2 at all times, it get's chuffing hot under the bonnet of these car's.
                                Awesome project by the way.
                                1990 B3 2.0 80 quattro.
                                1992 C4 2.8 Avant quattro
                                1994 MTM RS2.
                                1998 B5 TDI quattro Sport.
                                2000 B5 TQS.
